Hi Guys,
I've been kindly donated a pair of CX100s by our very own Leo, Thanks Leo!!! that are in need of some restoration, I spent all morning sanding and polishing the scratches out of the aluminium and I've given them a polish with coconut oil and I'm really happy with the look.
I then proceeded to remove all the old foam surrounds from the woofers for replacement and I noticed that one of the woofers is stuck fast. It won't move :-( I'm not sure what the problem is because it all looks fine to me.
So that leads me to the question.... I'm looking for a replacement... It's the one with the hole in the magnet that's jammed.
Fingers crossed, thanks in advance,
Lee
Hi Leo,
I've tried gently forcing it and it will move but it is very stiff. I'm going to take the dust cap off and see if I can see what's going off.
I'll post some pictures tomorrow
Thanks again!!
I managed to get hold of a replacement woofer for the stuck one... Turns out the same speaker on the other side (although freely moving) is dead :-( I've tested it with a multi meter and it has no continuity :-(
Can anyone help??
Anyone???
I have one, but it's in Denmark...
