Beocenter 9300 Speaker out
This post has 3 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Mon, Jun 25 2012 12:37 PM
Hello All
does anyone know the technical specs for the beocenter 9300
i have look on the product page and it says 2x80w Max power output with a frequency range from 70Hz.
there are 4 speaker terminals that i think can be used so i could bi wire both lefts and both rights to some biwired speakers if im right.
why does it not say 4x80W?
i know one was for speaker link but can this just be used as a normal speaker and Bi Wire them?
Cheers
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jun 25 2012 1:50 PM
It says 2x80W because there are two amplifier channels with each 80W of power.
The two pairs of outputs are just paralleled.
In other words; You won't get two more amplifier channels with 160 extra watts by loading the
same amplifier with two more speakers.
In my opinion, if you use standard B&O speakers cables you won't have to biwire anything and
it would certainly be overkill for an amplifier of this nature.
Seanie_230
UK
Posts 2,278
Hi there
I will just wire then up to a single pair of terminals then.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jun 25 2012 4:06 PM
Select SPEAKER 1 outputs. Speaker 1 can be muted using a Beoremote or the mute button on your BC9300. SPEAKER 2 are meant for a Mastercontrol link system for linkrooms. Maybe you consider RL 140 speakers for this purpose. I know Martin (Dillen) has a pair for sale...:)
Stefan
Page 1 of 1 (4 items) | RSS
