If you knew then what you know now - would you have bought a Moment?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Eclipse 65V1-32Beosound M5Essence MK2BLI
I would buy the Beosound Moment without hesitation.
No doubt, it will be the next addition to my setup.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Yes. It's certainly got it's quirks but it's getting better everyday and now it's an important part of the family instead of just a neat curiosity as it began a few weeks ago.
Michael
I waited until now to buy one because of what I knew then - since the moment was released. It's perfect.
yes definitely, despite installation issues and some improvements yet to be released
No.
Yes defenitly... I like the design, I like the sound coming from it, I like the Deezer and radio integration...
But there is still a lot of work on it to become more user friendly as a whole, the Beomusic app. per example. I'm waiting for: random play for DLNA playlists, bigger albums overview and tracks overview, etc... Please B&O rewrite the app. I'm getting so tired of using that small user menu in the app.
A fine example in a way I would like to see it is, the Audirvana+ remote..
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Yes I would have bought it. Nothing is prefect in the beginning when it is software related in my opinion, look how Apple started when they transitioned to OS X and even with the iPhone back in 2007.
This platform has all in it to be the next big thing on Audio for Bang & Olufsen. Think in a couple of years the Moment will be Iconic as the BeoSound 9000 for example
Erwin,
Thank you for your well considered response which has truly intrigued me.
I have often wondered why so many B&O fans (including myself) are willing to cut B&O so much slack!
I actually do worry a bit that this encourages B&O to rush things to market which are not fully baked.
The Moment is not a cheap trinket. It is supposed to be cutting edge produced by the world leader n luxury audio/video.
Would it not be reasonable to expect that this product works exactly as advertised and actually should exceed expectations.
Should one it expect an iconic product today
This is a little bit like Ferrari asking its customers to Beta test it's new 488.
