Location of Serial Number on BEOLAB 6000
alfio
Posts 59
alfio Posted: Sun, Dec 6 2015 9:26 PM
Hi
could someone tell where is located the serial number in the beolab speaker ?
Regards
Alfio
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Dec 6 2015 11:41 PM
Hi Alfio,
The label is located underneath the base of the speaker in the recess where the mains and powerlink connectors plug in.
Kind Regards,
Martin.
Sal
California, USA
Posts 1,197
Sal replied on Sun, Dec 6 2015 11:49 PM
I also think I've seen the label on the main body of the speaker if you remove the frets.
alfio
Posts 59
alfio replied on Mon, Dec 7 2015 7:00 AM
So you have to remove the base of beolab 6000?
I could not see iit with the base mounted.
alfio
Posts 59
alfio replied on Mon, Dec 7 2015 7:01 AM
Hi
under the fret there is a label but no s/n there.
Regards
9 LEE
Eastbourne, UK
Posts 7,218
Here is where the serial number can be found - I just took this photo for you Smile
Lay the speaker carefully on it's side and look underneath...
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Dec 7 2015 10:21 AM
9 LEE:
Thanks Lee,
I was about to reply to say it's on the side of the recess etc but it's definately one of those cases where a picture is worth a thousand words Smile
Martin.
alfio
Posts 59
alfio replied on Mon, Dec 7 2015 2:02 PM
THANKS
Page 1 of 1 (8 items) | RSS
