Hi
could someone tell where is located the serial number in the beolab speaker ?
Regards
Alfio
Hi Alfio,
The label is located underneath the base of the speaker in the recess where the mains and powerlink connectors plug in.
Kind Regards,
Martin.
I also think I've seen the label on the main body of the speaker if you remove the frets.
So you have to remove the base of beolab 6000?
I could not see iit with the base mounted.
under the fret there is a label but no s/n there.
Here is where the serial number can be found - I just took this photo for you
Lay the speaker carefully on it's side and look underneath...
9 LEE: Here is where the serial number can be found - I just took this photo for you Lay the speaker carefully on it's side and look underneath...
Thanks Lee,
I was about to reply to say it's on the side of the recess etc but it's definately one of those cases where a picture is worth a thousand words
THANKS
