Suddenly the Beomusic app is getting slow.
It take some time before it displays the sources. When I e.g choose Moment, I get the spinning symbol before the different sources under Moment are displayed. If I go into e.g. Music I get the spinning symbol before my albums are shown. Same if I select a song,
When I select a song or a TuneIN channel directly on the Moment Jukebox, it also takes time before I see something happening and hear sound.
I assume the Beomusic app communicating directly with all units individually in the network over Wifi.
I did a check on my phone, and it gets some 40 Mb/s over wifi, so it´s not the WIFI.
Anyone else experienced this?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Suddenly the Beomusic app is getting slow. It take some time before it displays the sources. When I e.g choose Moment, I get the spinning symbol before the different sources under Moment are displayed. If I go into e.g. Music I get the spinning symbol before my albums are shown. Same if I select a song, When I select a song or a TuneIN channel directly on the Moment Jukebox, it also takes time before I see something happening and hear sound. I assume the Beomusic app communicating directly with all units individually in the network over Wifi. I did a check on my phone, and it gets some 40 Mb/s over wifi, so it´s not the WIFI. Anyone else experienced this?
Hi Hiort,
I had the same experiences with the BeoMusic App on several ocassion.
There are different reasons
- BeoMusic-app (cache) on the iPad is spoiled. solution: delete app, download the app again and start the first setup.
- sometimes Deezer is not responding, therefore the App is trying to reconnect the whole time. Solution. Log out from deezer, restart the app Login again.
- same goes for TuneIn
- check your deezer account, how many devices are registered with your account
- your artist tiles are not fully processed, scroll down your artist and wait until all available tiles are there.
- last but not least - close unused Apps on the ipad, restart the ipad
I really do hope, that some of these hints will solve the issue 👏
Cheers Beroli
Beroli: - BeoMusic-app (cache) on the iPad is spoiled. solution: delete app, download the app again and start the first setup.
or go to the iPad setup, scroll to the Beomusic-app and choose to delete the cache
Carolpa: Beroli: - BeoMusic-app (cache) on the iPad is spoiled. solution: delete app, download the app again and start the first setup. or go to the iPad setup, scroll to the Beomusic-app and choose to delete the cache
🤔 forgot this solution - should be the first task, for sure - thank you Carolpa 😃
BeoNut since '75
