Playmaker LINE-IN Source
This post has 15 Replies | 4 Followers
Rubani
Posts 6
Rubani Posted: Tue, Jul 17 2012 8:44 AM
Dear people living in the Beoworld
I have a sound-system containing two beolab3, a Sony Bravia TV and a Playmaker.
I have connected the Playmaker LINE-IN socket and TV LINE-out socket with a Phono cable.
Now how do I make the Playmaker play through the Phono cable, and not Airplay?
Thanks in advance...
Vienna
make an educated guess
Posts 1,090
Vienna replied on Tue, Jul 17 2012 8:51 AM
Rubani:
 Welcome to the forum!
Select "A.AUX" via "LIST" on your Beo4 remote and press "GO"
Rubani
Posts 6
Rubani replied on Tue, Jul 17 2012 8:58 AM
Thank you for the answer
But I do not have a B&O remote, and have no intention of buying one
Vienna
Posts 1,090
Vienna replied on Tue, Jul 17 2012 9:23 AM
Rubani:
Erm.. ... page 9 of your Plamaker manual tells ...
The inputs are prioritized - the hirearchy is:
1 - AIRPLAY
2 - DNLA
3 - LINE IN
Starting a source with higher priority will interrupt a source  lower in hierarchy
therefore.a source with higher priority must be stopped to hear a source lower in hierarchy.
Rubani
Posts 6
Rubani replied on Tue, Jul 17 2012 9:47 AM
I noticed that, but it does not help turning my ipad/iphone off...
I will try a phono-minijack cable tonight. See if that helps.
I Just wanna make sure I don't need a remote. I have already used enough money on extra cables and stuff, to get this system up running.
Yendys
Sydney
Posts 312
Yendys replied on Tue, Jul 17 2012 10:01 AM
And also on page 10 "To activate Playmaker, start playback of any source"
Let us know how u get on
I'll be getting one when available in Australia
Vienna
Posts 1,090
Vienna replied on Tue, Jul 17 2012 11:41 AM
Rubani:
You don't have to turn the iDevice completely off - simply uncheck/de-select the Playmaker xxxxxxx in the
"Airplay List" of your iDevice (e.g. by selecting iPhone/iPad instead) and start the line source - in your case the TV.
Like the BeoSound 8 / BeoPlay A8 and BeoLit 12 the Playmaker uses "prioritisesed auto-sensing" to
switch between the inputs.
Rubani:
You don't need a remote to control a Playmaker, everything can be done "manually" on the unit itself or happens automatically.
Rubani
Posts 6
Rubani replied on Tue, Jul 17 2012 12:07 PM
Super. Thank you for the reply. We have kinda located the problem then. It must have something to do with the phono cable / TV.
I'll let your know when the problem is solved.
Vienna
Posts 1,090
Vienna replied on Tue, Jul 17 2012 12:21 PM
Rubani:
Just an idea ...
Are you 100% sure your Sony TV offers LINE OUT ?
A lot of today's TVs have just LINE INs and DIGITAL OUT( via Cinch or TOSLINK)
In that case you could use the headphones output of your TV as a workaround to connect to the Playmaker ...
Rubani
Posts 6
Rubani replied on Tue, Jul 17 2012 12:52 PM
I'm sure it offers line out yes. You know the little icon with a circle and an arrow pointing out of the circle. And then just a white and a red plug underneath.
Anyways, I have found a phono to jack cable, so I can use the headphones output as you suggest. I'll try it when I get home from work.
Rubani
Posts 6
Rubani replied on Tue, Jul 17 2012 8:37 PM
It works with headphone-output. FInally
Vienna
Posts 1,090
Vienna replied on Tue, Jul 17 2012 9:49 PM
Rubani:
Glad to hear it's working now!
Enjoy your Playmaker ...  Coffee  /  Drinks  /  Lets have a Party !!!
elephant
AU
Posts 8,219
elephant replied on Tue, Jul 17 2012 11:19 PM
Vienna:
Rubani:
Excellent ... now the unboxing photos, the in situ photos, and the review please Big Smile
BeoNut since '75
Vienna
Posts 1,090
Vienna replied on Tue, Jul 17 2012 11:49 PM
elephant:
Dear friend,
- Unboxing a Playmaker is far less spectacular than unboxing an A3 Sad
- Imagine a very thick white ceramic plate, tilted 54 degree from horizontal
  (I mesured this for you) and, with a little imagination you get the picture. Big Smile
- Is it still possible to tell "I like the product - at least for the sound" if it's not branded with a fruit logo?
   I'm not so sure anymore ... Confused
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 18 2012 11:14 AM
Vienna:
of course you can !
After all we are all loyal customers of Bananas & Oranges, fruitiers to the Royal House of Denmark
BeoNut since '75
elephant
AU
Posts 8,219
Vienna:
of course you can !
BeoNut since '75
Page 1 of 1 (16 items) | RSS
