Dear people living in the Beoworld
I have a sound-system containing two beolab3, a Sony Bravia TV and a Playmaker.
I have connected the Playmaker LINE-IN socket and TV LINE-out socket with a Phono cable.
Now how do I make the Playmaker play through the Phono cable, and not Airplay?
Thanks in advance...
Rubani:Now how do I make the Playmaker play through the Phono cable
Welcome to the forum!
Select "A.AUX" via "LIST" on your Beo4 remote and press "GO"
Thank you for the answer
But I do not have a B&O remote, and have no intention of buying one
Rubani: But I do not have a B&O remote, and have no intention of buying one
... page 9 of your Plamaker manual tells ...
The inputs are prioritized - the hirearchy is:1 - AIRPLAY2 - DNLA3 - LINE IN
Starting a source with higher priority will interrupt a source lower in hierarchytherefore.a source with higher priority must be stopped to hear a source lower in hierarchy.
I noticed that, but it does not help turning my ipad/iphone off...
I will try a phono-minijack cable tonight. See if that helps.
I Just wanna make sure I don't need a remote. I have already used enough money on extra cables and stuff, to get this system up running.
Rubani: I noticed that, but it does not help turning my ipad/iphone off...
You don't have to turn the iDevice completely off - simply uncheck/de-select the Playmaker xxxxxxx in the "Airplay List" of your iDevice (e.g. by selecting iPhone/iPad instead) and start the line source - in your case the TV.
Like the BeoSound 8 / BeoPlay A8 and BeoLit 12 the Playmaker uses "prioritisesed auto-sensing" to switch between the inputs.
Rubani: I Just wanna make sure I don't need a remote. I have already used enough money on extra cables and stuff, to get this system up running.
You don't need a remote to control a Playmaker, everything can be done "manually" on the unit itself or happens automatically.
Super. Thank you for the reply. We have kinda located the problem then. It must have something to do with the phono cable / TV.
I'll let your know when the problem is solved.
Rubani: It must have something to do with the phono cable / TV.
Just an idea ...
Are you 100% sure your Sony TV offers LINE OUT ?
A lot of today's TVs have just LINE INs and DIGITAL OUT( via Cinch or TOSLINK)In that case you could use the headphones output of your TV as a workaround to connect to the Playmaker ...
I'm sure it offers line out yes. You know the little icon with a circle and an arrow pointing out of the circle. And then just a white and a red plug underneath.
Anyways, I have found a phono to jack cable, so I can use the headphones output as you suggest. I'll try it when I get home from work.
It works with headphone-output. FInally
Rubani: It works with headphone-output. FInally
Glad to hear it's working now! Enjoy your Playmaker ... / /
Vienna: Rubani: It works with headphone-output. FInally Glad to hear it's working now!
Excellent ... now the unboxing photos, the in situ photos, and the review please
BeoNut since '75
elephant: Excellent ... now the unboxing photos, the in situ photos, and the review please
Dear friend, - Unboxing a Playmaker is far less spectacular than unboxing an A3 - Imagine a very thick white ceramic plate, tilted 54 degree from horizontal (I mesured this for you) and, with a little imagination you get the picture. - Is it still possible to tell "I like the product - at least for the sound" if it's not branded with a fruit logo? I'm not so sure anymore ...
Vienna:- Is it still possible to tell "I like the product - at least for the sound" if it's not branded with a fruit logo?
of course you can !
After all we are all loyal customers of Bananas & Oranges, fruitiers to the Royal House of Denmark
