I've just installed a MLGW (the MasterLink version - not the newly released NetLink version). In using the BeoLink app on my iPad, the app keeps crashing when browsing music from the BeoSound 5. The iPad mini is only about 6 months old and has the recent software. The BeoSound 5 and the MLGW also have the latest firmware. I don't have this problem when using the NetLink app on my iPhone, however. Has anyone else encountered this issue and found a solution?
Tried to reinstall it?
I just tried your suggestion. It still crashes. I'm worried that it might have something to do with the fact that when I loaded my music library, it was when the BeoConnect was an earlier version that merely dumped all of the songs onto the hard drive instead of organizing the music into folders and subfolders as it now does. Any thoughts?
BTW, my Beo6 works fine navigating the music from the BeoSound 5.
I just closed all apps and did a hard restart on all of my iOS devices, restarted my computer, restarted my airport extreme, restarted my BLGW, and restarted my BeoSound 5. Something I did fixed the problem. The app is now working beautifully without crashing. I'm very impressed with the tablet interface of the music stored on my BeoSound 5. This alone was worth the cost of the MLGW. Now if only the app would include a similar interface for N.RADIO and Spotify....
It seems I spoke to soon. The app is again crashing. It seems that it crashes only after I have accessed the n.music stored on the BeoSound 5 / Beomaster 5. The only way to stop the crashing is to reboot the BeoSound 5 and not access it via the iPad.
beojeff:It seems I spoke to soon. The app is again crashing. It seems that it crashes only after I have accessed the n.music stored on the BeoSound 5 / Beomaster 5. The only way to stop the crashing is to reboot the BeoSound 5 and not access it via the iPad.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
I think you're on to something here. My main Airport Extreme is located in the den, but I have another Airport Extreme in the living room to use as an access point to extend the signal. I seem to recall in the instructions for using the Beo6 with the BeoSound 5 something about needing to select the specific access point that is closest to the Beo6. I'm not sure how to do that in the BeoLink App, though.
I've located the crash log for the BeoLink App and am pasting the log details of the relevant thread that crashed. Perhaps one of our computer language savvy BeoWorlders can find the problem in this log?
Thread 7 Crashed:
0 libsystem_kernel.dylib 0x39df81f0 0x39de5000 + 78320
1 libsystem_pthread.dylib 0x39e62792 0x39e5f000 + 14226
2 libsystem_c.dylib 0x39da8fd8 0x39d60000 + 298968
3 libc++abi.dylib 0x390d7cd2 0x390d7000 + 3282
4 libc++abi.dylib 0x390f06e0 0x390d7000 + 104160
5 libobjc.A.dylib 0x39835f62 0x39832000 + 16226
6 libc++abi.dylib 0x390ee1c4 0x390d7000 + 94660
7 libc++abi.dylib 0x390eda18 0x390d7000 + 92696
8 libobjc.A.dylib 0x39835d9e 0x39832000 + 15774
9 CoreFoundation 0x2ec6bf10 0x2eb98000 + 868112
10 Foundation 0x2f597326 0x2f586000 + 70438
11 Foundation 0x2f5971ec 0x2f586000 + 70124
12 RbeoR1 0x000b7900 0x65000 + 338176
13 RbeoR1 0x000abed8 0x65000 + 290520
14 RbeoR1 0x000b5004 0x65000 + 327684
15 RbeoR1 0x000b5bd8 0x65000 + 330712
16 RbeoR1 0x000b3592 0x65000 + 320914
17 Foundation 0x2f654a5a 0x2f586000 + 846426
18 libsystem_pthread.dylib 0x39e61916 0x39e5f000 + 10518
19 libsystem_pthread.dylib 0x39e61886 0x39e5f000 + 10374
20 libsystem_pthread.dylib 0x39e5faa0 0x39e5f000 + 2720
My system does the same thing when the MLGW is set to browse the music on the BeoSound5, when I remove this feature the app does not crash I can work everything normally, admittedly with no artwork from N.MUSIC
A few months ago, I found the reason for my app crashing: There was a song file with an unusually long track name. Such ridiculously long names can sometimes be assigned to classical and opera songs when you rip a cd into iTunes and rely on iTunes to fill in the tagging for you. After re-tagging the song with a reasonable name, the crashing problem went away.
I also have logos for n.radio stations by creating a favorites list, but I have not had any problems with it causing crashing.
w5bno123:When I opened up my BeoLink App several weeks ago and selected N.Music it no longer displayed the music from the BeoSound 5. No updates have happened on my Draytek 2820 router or Cisco access points. The product is seen on the network and other DNLA app on my iPad and it is still controlled by the app. The IP address matches, I have stripped my network and system down to just the router, app, Bsnd 5 and MLGW and still no joy Any suggestions please...
StUrrock:The problems are to do with iOS recent updates will try with an android box tomorrow
olvisab:I don't want to make the ios8 jump because I don't want to mess everything. Hope you will find the cause. beosound 5/BM5 , beosystème 4500 , beolab 1, beolab 5000, beolab 14, beolab 3500, beovision av 9000, IWS 2000, beotime, MLGW
StUrrock:http://archivedforum2.beoworld.org/forums/p/4606/41726.aspx#41726 Android app no longer available and Beolink does not work with current iOS? TOTAL joke!!
mjmedlo:I'm confused? Mine works great. Granted it's an NL gateway but the app is the same.
StUrrock:I'm confused I've got an MLGW and it don't work
No problems here.
Works with: MLGW sw 2.22, BM5 sw 7.0.3., ipad IOS 8.0.2., 2nd ipad IOS 7..., Beo6 and iphone4 with latest Beolink app update.
Stefan
StUrrock:Problem now isolated, when the network cable is pulled out of the BS5, the app never crashes. Think it is loading the album info etc in NMUSIC that is causing the problem.
StUrrock:Problem now isolated, when the network cable is pulled out of the BS5, the app never crashes.Think it is loading the album info etc in NMUSIC that is causing the problem.
Under the reachable gateway, make sure you have extended timeout checked. Then reboot all devices again.
Ah, you know... A little B&O here, a little there
I have just installed Mlgw, and did have a similar problem with crashing beolink app. I found that songs with long filename seams to be the problem.
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
