Beogram 120x pitch adjuster
This post has 24 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Tue, Feb 9 2016 9:06 AM
What is material of this tip?
What have people use for replacement? (this is still present, on other deck, 5228, is not)
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 9 2016 1:11 PM
The round thingy at the outermost end of the lever, is a fiber pad.
I suppose there could be many ways to replace it but I like to take one of the little red fiber washers that
B&O used heavily during the 70's for circuitboard screws,cut two small and thin pieces out of it and glue
onto the metal using a good slow-setting 2-comp. epoxy (I use Araldite Standard).
Søren Mexico
Mexico City
Posts 6,411
As the whole copper tongue on mine (BG 1000) was gone  I made it like this with a piece of hard plastic, as Martin I glued with epoxy
Orava
Finland
Posts 991
Orava replied on Tue, Feb 9 2016 5:36 PM
oh well, to fast fingers... double post
Orava
Finland
Posts 991
Thank you both. Something like that I was thinking, teflon in fact but, as usually when needed, did not found mine...
So plastick it will be, I was only unsure do araldit hold it.
Orava
Finland
Posts 991
Orava replied on Tue, Feb 9 2016 5:39 PM
Here is more nuts from 2000 (Edit: 1203 actually). Did not find any pictures about this kind startswitch.
I totally confused how it should work!
Orava
Finland
Posts 991
Orava replied on Tue, Feb 9 2016 5:41 PM
Or where it should connect
Orava
Finland
Posts 991
Orava replied on Thu, Feb 11 2016 8:39 AM
Oh my, so simple that it is allmost stupid. It is right where it should be, so simple that I could not see it Surprise
Orava
Finland
Posts 991
Orava replied on Thu, Feb 11 2016 8:46 AM
Next mystery. Where did this came from?
Or is it from this (1203) at all?
Søren Mexico
Mexico City
Posts 6,411
Orava:
Maybe part of the muting switch
Dillen
Posts 13,191
Dillen replied on Thu, Feb 11 2016 2:22 PM
That's a part from the cam wheel.
See here:
http://beoparts.com/2015/12/19/beogram-cam-wheel-3017010/
Orava
Finland
Posts 991
Orava replied on Thu, Feb 11 2016 6:03 PM
Dillen:
See here:
Right, thats it. Hope I dont miss anything else here. (exept brass moutings of it)
Dillen
Posts 13,191
Dillen replied on Thu, Feb 11 2016 6:42 PM
I think, you should be looking for one more bronze plate, smaller than the one you already found.
If I'm not mistaken it should sit behind the other one.
Orava
Finland
Posts 991
Orava replied on Fri, Feb 12 2016 8:37 AM
There is none :(
Should be easy to remake, only if had model...
It is for end stop I guess. Maybe 3000 has similar?
Orava
Finland
Posts 991
Orava replied on Fri, Feb 12 2016 10:01 AM
Not exactly same, but...
Orava
Finland
Posts 991
Orava replied on Fri, Feb 12 2016 1:44 PM
It works, but it is not compatible as whole since top is different.
Orava
Finland
Posts 991
Orava replied on Mon, Feb 15 2016 5:38 PM
New one:
Orava
Finland
Posts 991
Orava replied on Mon, Feb 15 2016 5:41 PM
Yet, one happy Beogram
Not the prettiest one, but good practice, and it is working :)
Dillen
Posts 13,191
Dillen replied on Mon, Feb 15 2016 9:40 PM
Very nice DIY-job!
Next, put the word "LIFT" on the pushbutton :-)
Søren Mexico
Mexico City
Posts 6,411
Dillen:
Very nice DIY-job!
Very good job Orava, send the push button to Frede he can put LIFT on it the next time he remake fronts for the BL 5000 classicBig Smile
Bad joke, leave it like it is, looks good anyway
Orava
Finland
Posts 991
Orava replied on Tue, Feb 16 2016 12:12 PM
It is plain plastic sticker, touhg a good one Big Smile
It is allways nice work with equpment when someone else has done something you dont know...
Orava
Finland
Posts 991
Orava replied on Thu, Feb 18 2016 10:59 AM
Back where this (misnamed) thread starts. New pads for 3000 pitch control:
So, under work now 3000, with 2000 top cover
Orava
Finland
Posts 991
Orava replied on Wed, Feb 24 2016 9:33 AM
Orava:
Problem:
And my method to solve:
An clamp, this aluminium, 1mm thick 5x6x6 inside measure
1mm groove to plastic right next to aluminium wall
Clamp to groove.
For other side, please flip pictures
Will need some finishing touch.
Orava
Finland
Posts 991
Orava replied on Mon, Feb 29 2016 9:28 AM
With fininshing touch
Dillen
Posts 13,191
Dillen replied on Mon, Feb 29 2016 10:43 PM
Well done!
Page 1 of 1 (25 items) | RSS
