What is material of this tip?
What have people use for replacement? (this is still present, on other deck, 5228, is not)
The round thingy at the outermost end of the lever, is a fiber pad.I suppose there could be many ways to replace it but I like to take one of the little red fiber washers thatB&O used heavily during the 70's for circuitboard screws,cut two small and thin pieces out of it and glueonto the metal using a good slow-setting 2-comp. epoxy (I use Araldite Standard).
As the whole copper tongue on mine (BG 1000) was gone I made it like this with a piece of hard plastic, as Martin I glued with epoxy
oh well, to fast fingers... double post
Thank you both. Something like that I was thinking, teflon in fact but, as usually when needed, did not found mine...
So plastick it will be, I was only unsure do araldit hold it.
Here is more nuts from 2000 (Edit: 1203 actually). Did not find any pictures about this kind startswitch.
I totally confused how it should work!
Or where it should connect
Oh my, so simple that it is allmost stupid. It is right where it should be, so simple that I could not see it
Next mystery. Where did this came from?
Or is it from this (1203) at all?
Orava:Or is it from this (1203) at all?
Maybe part of the muting switch
That's a part from the cam wheel.
See here:
http://beoparts.com/2015/12/19/beogram-cam-wheel-3017010/
Dillen: That's a part from the cam wheel. See here: http://beoparts.com/2015/12/19/beogram-cam-wheel-3017010/ Martin
Right, thats it. Hope I dont miss anything else here. (exept brass moutings of it)
I think, you should be looking for one more bronze plate, smaller than the one you already found.If I'm not mistaken it should sit behind the other one.
There is none :(
Should be easy to remake, only if had model...
It is for end stop I guess. Maybe 3000 has similar?
Not exactly same, but...
It works, but it is not compatible as whole since top is different.
New one:
Yet, one happy Beogram
Not the prettiest one, but good practice, and it is working :)
Very nice DIY-job!Next, put the word "LIFT" on the pushbutton :-)
Dillen: Very nice DIY-job!Next, put the word "LIFT" on the pushbutton :-) Martin
Very good job Orava, send the push button to Frede he can put LIFT on it the next time he remake fronts for the BL 5000 classic
Bad joke, leave it like it is, looks good anyway
It is plain plastic sticker, touhg a good one
It is allways nice work with equpment when someone else has done something you dont know...
Back where this (misnamed) thread starts. New pads for 3000 pitch control:
So, under work now 3000, with 2000 top cover
Orava: Problem: And my method to solve: An clamp, this aluminium, 1mm thick 5x6x6 inside measure 1mm groove to plastic right next to aluminium wall Clamp to groove. For other side, please flip pictures Will need some finishing touch.
Problem:
Clamp to groove.
With fininshing touch
Well done!
