Best version of speaker Beolab 8000
This post has 4 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Sun, Aug 5 2018 4:15 PM
Dear members,
which version of the Beolab 8000 is the best sounding in your view? I have compared MK 1 pre and post ABL and they sound very different. Has anyone compared MK 1 ABL to MK 2 or 8002? Insights would be much appreciated.
Thanks!
Kai
Hungedu
United States
Posts 165
Hungedu replied on Mon, Aug 6 2018 4:03 PM
I have a pair of MK1 and MK2 BL-8000s. The MK2 sounds a bit more crisp, so I keep the MK2 speakers up front and use the older MK1 speakers as surrounds.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Aug 6 2018 4:33 PM
Hungedu:
By Mk1 do you mean the first gen ones that had the woofers wired with a passive crossover so it was a nominally 3, or 2.5, way speaker? Is the Mk 2 the ones that went to the woofers wired together as a true 2 way but before the 8002 that used ICE amps? I've never heard the originals, always have wanted to though.
Jeff
Hungedu
United States
Posts 165
Hungedu replied on Mon, Aug 6 2018 5:01 PM
To be perfectly honest, I don't know how the 8000s were internally wired over the years. My MK1 Beolab 8000s were purchased new in 1993, and my MK2 versions were purchased new in 2006. There is a subtle audio difference, but mainly in the higher frequencies.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
