ScottMacK: 1. Apps. The BeoSetup and BeoMusic Apps randomly have trouble finding the A6 on my WiFi network. I know the A6 is on the network because I can touch it and it starts streaming TuneIn and I can also send music to it via AirPlay. But sometimes I can't see it or control it with the BeoApps. Is this an issue others have experienced?
Not much help to you, but I have never had that problem. Try restarting your router.
ScottMacK: 2. Sources. The BeoSetup app contains a list of sources I can enable/disable/reorder. I believe this list sets the order of sources I can touch the A6 to activate. Is that correct? What is the "Music" source? Is it DLNA?
ScottMacK: 3. DLNA. I would love to be able to start _my_ music playing on the A6 by touching it. However, my music is currently stored in iTunes on my Mac and AirPlay must be activated separately. Would DLNA and something like Twonky Server give me that ability?
Yes. Setup Twonky to serve your music to A6. That the way I have done it.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
With #1 I've found that on iOS, force quitting the BeoMusic App, and restarting helps when my BeoMusic app doesn't see the Essence / A6. I think it needs to purge something possibly, but I really don't know why, but for me, when there's a hiccup like the App not seeing one of the products, doubleclicking the home button, swiping up to stop the instance of the App and then restarting BeoMusic, does the trick.
