What mediaplayer for Beovision 14 (if needed )
This post has 6 Replies | 0 Followers
sq2002
Posts 58
sq2002 Posted: Wed, Nov 16 2016 8:17 AM
Hi everyone,
My new Beovision 14, 55" has just been installed. I have played a little with the Android software and installed the Kodi app as mediaplayer.
Before I had the BV10 with a seperate mediaplayer (Mede8er MED600X3D)
Maybe a dumb question but as this is a ultra HD television and it has now Kodi running, do I still need a seperate mediaplayer ? I already did a quick test and it plays trough Kodi DVD and Blue Ray rips without a problem but not sure if the BV14  play at the righ resolution if I use the android app's ?
On the specs of the BV14 I see this : VP9- and HEVC-codecs are integreded for streaming 4K content from for example Netflix or Youtube.
Is this enough, or do I still need a seperate mediaplayer for the Ultra HD movies ?
If needed a seperate mediaplayer, what would you recommend in combination with the BV14 ?
Thanks !
koning
holland
Posts 4,220
koning replied on Wed, Nov 16 2016 8:43 AM
Dune 4k solo
sq2002
Posts 58
sq2002 replied on Wed, Nov 16 2016 9:59 AM
@ koning : thanks.
Can you explain why I need this one, so an additional mediaplayer ?
koning
holland
Posts 4,220
koning replied on Wed, Nov 16 2016 10:26 AM
Full blueray menu's
Vxp video scaler
Buildin movie scraper
sq2002
Posts 58
sq2002 replied on Wed, Nov 16 2016 11:34 AM
If I install the KODI app, I have also the scraper and full blueray menu.
Is it the playback that is different ?
koning
holland
Posts 4,220
koning replied on Wed, Nov 16 2016 2:35 PM
It is not possible to install kodi on the dune.
sq2002
Posts 58
sq2002 replied on Wed, Nov 16 2016 3:17 PM
No, I installed Kodi on the Beovision 14 that runs on Android.
Page 1 of 1 (7 items) | RSS
