BeoNut since '75
Aussie Michael:Hi Thought I would take a moment to write a post about something i was playing around with yesterday.Some of you may know, or now know, that I have the Toshiba BR player with bracket that I purchased from STB Brackets.Yesterday I was in JB HiFi (a music and electronics store) and decided I was going to buy some physical media (CDs) and I thought perhaps I could use the Toshiba player to do this and would post my findings on the forum.> A CD can be played quite successfully in the player - I know some ppl like dedicated CD players > I changed the sound mode on the avant to be "music" and wow did that make all the difference> I used the B&O app to send the source to the A9 in the dining room and then the A6 in the "bedroom *** study" > With this Multiroom set up I then turned off the Avant using the BR One and it turned off the Avant and pushed the stand in to its "standby" or "home" setting and the A9 and the A6 continued to play> If I pressed in the middle of the A9 with both the A9 and the A6 playing the A9 would stop playing and the A6 would continue to play> If I pressed the power button (standby) on the A9 as it was quiet and the a6 was still audible all products would turn off All 3 products, Avant, A9 and A6 are wireless and in separate rooms I used a mix of BR One, BeoRemote App, and B&O Play app. I came to the thinking it would be good to have the 2 apps blended in to one, or have the BR App have the Multiroom functionality so you don't have to flip through 2 apps if you want to change the source back and forth. And I was playing Iggy Azalea! Haha. Some of you may cringe. :-)
