Hi I have recently purchased a second hand beosound 4 and am having a problem with the volume . The unit seems to be stuck on very low volume and wont adjust manually and remote control is unresponsive. I have tried to access the sound menu but this menu seems to be locked or not working .Any help would be very much appreciated
Scott
I have exactly the same problem, any help would be appreciated. My unit also does not recognize either the beo4 remote nor the older remotes, is there a way to factory reset and see if that works?
Regards
Dear Kai,
I switched off the beosound 4 as well as the MCL2P at the wall switch, and switched it on again, then the remote responded, so I set the mode to 1 i.s.o. of 0 the previous owner had it on, and it works 100% now. Thank you for your assistance, most appreciated.
Leo
