Hello,
According to you, can we use a bv 10's stb wall bracket for a bv 11 ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab: According to you, can we use a bv 10's stb wall bracket for a bv 11 ?
If I remember correctly, no! I had a BV10 and moved up to a BV11 and they had to remove the old bracket and install a new one.
I had this: http://www.stbbrackets.co.uk/en-GB/product/beovision-10-46-and-40/beovision-10-close-wall-bracket
Had to change to this: http://www.stbbrackets.co.uk/en-GB/product/beovision-11-46-and-40/beovision-11-close-wall-bracket
Thanks Moxxey.
Yes you can!
I replaced my BV 10-46 with BV 11-55 at my summer house. I ordered a new wall bracket but used the old one.
The bracket was "close wall bracket".
