Hi Michael,
Yes, you can link the PlayMaker into the AV socket of your Avant (assuming this is the new 55/75/85 inch Avant, not the 1990s 28/32 inch Avant!) using the cable and adapter in the links below:-
1) Cable: http://soundsheavenly.com/input/138-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html
2) Adapter: http://soundsheavenly.com/bang-olufsen/30-rj45-to-powerlink-compatible-clip-on-adapter-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html
This will allow the speakers to play music from the PlayMaker via the Avant. The only downside of this is that the Avant needs to be on to play music (although you can use the P.MUTE function to turn off the screen).
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Thanks Steve
I was trying to not use the Avant but will give it a go. I think i have those cables that I purchased from you before, so when i get a spare moment, i'll give it a whirl.
Cheers, and thanks for the reply.
