Can you integrate receiver 1 and PM
Aussie Michael
Melbourne, AU
Posts 3,730
Aussie Michael Posted: Sat, Sep 3 2016 2:59 AM
Hi
Am thinking about my BL3s that I don't use.
I have set them up in my front lounge room with the wireless receiver 1s which is in a different room to my avant.
I have set a speaker group 4 as lounge when I want to use them. This morning I was listening to Chilltrax on the avant then used the speaker group and then tapped my a9 and had multi room using both WISA and the NL.
That got me thinking can I integrate my PM which is gathering dust with the BL3 AND the wireles receiver 1s?
If so how would I do this ?
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Michael,
Yes, you can link the PlayMaker into the AV socket of your Avant (assuming this is the new 55/75/85 inch Avant, not the 1990s 28/32 inch Avant!) using the cable and adapter in the links below:-
1) Cable: http://soundsheavenly.com/input/138-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html
2) Adapter: http://soundsheavenly.com/bang-olufsen/30-rj45-to-powerlink-compatible-clip-on-adapter-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html
This will allow the speakers to play music from the PlayMaker via the Avant.  The only downside of this is that the Avant needs to be on to play music (although you can use the P.MUTE function to turn off the screen).
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Aussie Michael
Melbourne, AU
Posts 3,730
Thanks Steve
I was trying to not use the Avant but will give it a go.  I think i have those cables that I purchased from you before, so when i get a spare moment, i'll give it a whirl.
Cheers, and thanks for the reply.
Page 1 of 1 (3 items) | RSS
