Will the speaker display work on my penta 2's when used with the beosound 9000 using the 7-din pin connecting cables? thanks for reading and letting me know, Rob
No, you need to use 8 pin fully connected (used to be called Mk2) powerlink cables.
Regards Graham
moser26:Will the speaker display work on my penta 2's when used with the beosound 9000 using the 7-din pin connecting cables? thanks for reading and letting me know, Rob
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I have a BS9000 connected to Beolab Penta II's (via Beolink Wireless) and they work fine. You do need the fully wired (thicker) cables as Graham states. I thought my Pentas were broken when using the thin cables I had.
Stoobie
