Wierd problem has arrised. Over a period of a couple of days, my Beosound 5 will not connect to Spotify.
in red text, is says "no internet connection" when Spotify is selected, but it is connected. The Radio part works fine.
anyone ?
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
gysse2004:Wierd problem has arrised. Over a period of a couple of days, my Beosound 5 will not connect to Spotify. in red text, is says "no internet connection" when Spotify is selected, but it is connected. The Radio part works fine. anyone ? peter
I'm the same symptoms. I do not know whether this is a temporary failure. Is there anyone who tell you how to fix ?
This is being broken are the symptoms?
really ? This is being broken are the symptoms?
I also have exactly the same problem since a day. My mother board has been replaced already for a lot of money a few years ago, so I hope it's not the same problem. Are there people who found other solutions?
Just spoke with my Bang & Olufsen dealer, and they have the same problem. So maybe it's something to do with Spotify.
Same here. Had this sympton last weekend for some minutes - red line and "no internet connection".
My first thought was, somebody else in the house was accessing Spotify, but no one did.
After a few minutes Spotify came back and worked properly. I will test it once more tonight.
Stefan
Mine is saying "NO"
Peter
I have the same problem with Spotify here in the US, and my network connection says "no"... yet, n.radio works fine and I can access the BM5 via my computer. Good news: I don't think all of our main boards just faulted. Bad news: It doesn't work and will B&O still support? Personally, I blame Microsoft!
My software versions are:
BS5/BM5 Application: 7.04.01.1945
BS5 Main firmware: 1.38a
BS5 Boot firmware: 0.04a
BM5 ML Firmware: 2.36
BM5 ML PCB: 4
BM5 MB Bios: 1.15
BM5 OS Image: 5.00
BM5 OS Update: 7.03
Last N.Radio Update: 2016-08-21
Stan
It definitely makes no sense. I rarely use Spotify from my computer, but I cannot find any "favourites" (or favorites ). I deleted my "starred items", and that didn't seem to do anything.
Stan: I cannot find any "favourites" (or favorites ).
did anyone searched at Spotify, if it still supports Windows XP.
maybe they don't accept connections from XP.
I think you are right about Windows, if I go into the service menu, internet explorer cannot go online..
Just checked my Beosound 5. Same problem. I have been thinking about canceling Spotify as Deezer Elite sounds so much better. But I liked the functionality of Spotify on the Beosound 5. This makes the decision for me...time to cancel Spotify.
Found this post on Spotify that as of right now says it was posted 16 hours ago. Looks like the problem may not be just with Beosound 5s.
https://community.spotify.com/t5/Desktop-Linux-Windows-Web-Player/Offline-error-no-internet-connection-available/td-p/1433245
Razlaw:Found this post on Spotify that as of right now says it was posted 16 hours ago. Looks like the problem may not be just with Beosound 5s.
I have an Essence also. But sometimes the Beosound 5 is just more enjoyable to use. Turning the wheels and having the cover art displayed on it and enjoying the product along with the music.
I have the same problem - Spotfy does not function, but N.Radio
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
Reply back from Struer, they are working with Spotify to find a solution asap..
''Tak for din henvendelse til Bang & Olufsen kundeservice vedrørende den manglende adgang til Spotify fra BeoSound 5.Vi er opmærksomme på problemet og arbejder sammen Spotify på at finde en løsning hurtigst muligt. Med venlig hilsenBang & Olufsen a/s''
What's that in English? Sorry!
interesting would be if one installs Google Chroome or Firefox as preferable browser on the BM5.
what would happen than?
I can't test it anymore.....................
Hello,
I am having the same issue as mentioned by OP. A few days ago it started. It says 'No internet connection' in red text when trying to open Spotify. Also, it states 'NO' at 'Network connection'. You can tell there is actually an internet connection, because when trying to search for updates, it says there are no updates available, but when trying to search for updates without the network cable connected, it says that there is no connectivity. I didn't try to delete all my playlists in Spotify, yet. I have a lot! Also, about a week ago, the loading of the playlists started to take up more time then usual (couple of minutes, instead of a few seconds).
I hope they find a solution for this Spotify problem.
Regards,
Geert.
Could be possible to make a free trial period account with no playlist, just to check!
Spotify support sent me some test log in credentials to try. The same error problem occurred with the log in Spotify asked me to try.
It is working again, connection is saying "yes", and Spotify is running. Playlist is loading slow, but working !!!
gysse2004:It is working again, connection is saying "yes", and Spotify is running. Playlist is loading slow, but working !!! Peter
Yes, Spotify is working again on my BS5.
Thank you Razlaw and Peter (gysse2004).
Mine is working also.
