Hello,
I have a new Essence MK2 with latest firmware. Everything works well. I control it with beomusic app. With the source TuneIn Radio I face a problem with one specific radio station "Superfly FM".
The essence tries to find or play the station for about 5 seconds and then shifts to the next station in my favourite list. I also tried to start the station from the sender list (not the favourite) - no succeess.
When I open the tuneIn App on the iphone or iPad the station plays without a problem and I can stream it to the essence. So it is not a network issue.
I tried to change the buffer from 5 to 10 and back to 3 seconds. No change in behaviour.
Any idea? The stupid thing is, that this is the favourite station of my wife and one of the reasons to buy the essence...
Thanks,
Heribert
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Heribert:Hello, I have a new Essence MK2 with latest firmware. Everything works well. I control it with beomusic app. With the source TuneIn Radio I face a problem with one specific radio station "Superfly FM". The essence tries to find or play the station for about 5 seconds and then shifts to the next station in my favourite list. I also tried to start the station from the sender list (not the favourite) - no succeess. When I open the tuneIn App on the iphone or iPad the station plays without a problem and I can stream it to the essence. So it is not a network issue. I tried to change the buffer from 5 to 10 and back to 3 seconds. No change in behaviour. Any idea? The stupid thing is, that this is the favourite station of my wife and one of the reasons to buy the essence... Thanks, Heribert -------------------------------------------------------------------------------------------------- BV 11-46 / Apple TV 1+3 / Beomedia 1 / BL3 / 2* BL11 / BL 6000 / BL 2000 / 3 * Beo4 / Masterlink over Ethernet
Hi Michael,
* Yes, can you please do me the favour to try on your?
* yes, it is stored in the favourites seen in beomusic app. I added it first on the computer and after having "unliked" it also again in Beomusic App
So, ich habe den Sender jetzt mehrere Stunden gehört. Er lief konstant durch. Einmal ist er mir weggerutscht und ich hatte den nächsten Sender.
Hast du eine feste IP Adresse der Essence zugeordnet? Ich denke es liegt an deiner Internetverbindung oder direkt am Sender. Ich habe ein ähnliches Problem mit meinem "Mallorca Inselradio". Oftmals kein Empfang oder kontnuierlicher Abbruch nach einigen Minuten. Da liegt es aber am Sender und die Lautstärke ist zu anderen Internetsendern total übersteuert (zu laut). Da war der Empfang über die Essence beser als über die BS5 (die ist noch sensibler). Dann hilft es auch nicht den Zwischenpuffer zu erhöhen.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass, BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence , BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white, Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
Stevegee:Hi Heribert, I just tried it on my Essence mk2 and I can't play it on beomusic here in the UK either. Everything else works fine - apart from Superfly FM. It works when just played on the tunein app on my iPad though, strange! Sorry couldn't help more, I don't know much about Internet radio, so can't offer a solution or answer why.
Thank you both for testing. I was playing a little with my network settings, but without success.
One question: My essence has a LAN cable plugged in and also connects via WLan (Wifi) with my network. Which connection is used for the stream? can I decide this?
Heribert:Hi Michael, * Yes, can you please do me the favour to try on your? * yes, it is stored in the favourites seen in beomusic app. I added it first on the computer and after having "unliked" it also again in Beomusic App -------------------------------------------------------------------------------------------------- BV 11-46 / Apple TV 1+3 / Beomedia 1 / BL3 / 2* BL11 / BL 6000 / BL 2000 / 3 * Beo4 / Masterlink over Ethernet
This station changed its lifestream url and TuneIn did not updated it yet. Edit the station in the Tunein form on the their website and submit the new adress to the correct new url for this station on the form. In one day or a couple of days it will be corrected by TuneIn.
http://stream01.superfly.fm:8080/live.m3u
EDIT: In the mean time you can add the above stream url adress to TuneIn as a custom url on your TuneIn profile. It will be without the nice logo and will be the first on your profile... (as an interim solution to satisfy your wife)
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
@Chris: It finally works. I did as you suggested and sent a note to TuneIn. Then it took another hour and then it worked. The workaround did not succeed, it was alwasy greyed out in BeoMusic, even when it worked on the Mac.
Heribert: @Chris: It finally works. I did as you suggested and sent a note to TuneIn. Then it took another hour and then it worked. The workaround did not succeed, it was alwasy greyed out in BeoMusic, even when it worked on the Mac.
Hi Heribert
Are you sure its ok, that fast?
The station gives me a still a fault on the TuneIn website...
Normally it takes at most max. 48 hours to get a respons from the broadcast team at TuneIn.
I sended also the new url on the update page to their broadcast team and I'm waiting now to get a mail respons.
The url link I have giving you is indeed working on Safari and forwarded by me to TuneIn, but it could be that its not actually working on Beomusic.
It works on the Moment anyway.
To be continued...
TuneIn did not reply yet, but the sender started to work - perhaps they were already updating the station before I wrote. Most important: it works. Thanks again
Chris: This station changed its lifestream url and TuneIn did not updated it yet. Edit the station in the Tunein form on the their website and submit the new adress to the correct new url for this station on the form. In one day or a couple of days it will be corrected by TuneIn. http://stream01.superfly.fm:8080/live.m3u
Does this trick work for other stations? Tunein can no longer play J-Pop Project Radio and I was wondering if I can find the stream address and do it this way. Any way to find the stream address, if so???
Mark-N:Does this trick work for other stations? Tunein can no longer play J-Pop Project Radio and I was wondering if I can find the stream address and do it this way. Any way to find the stream address, if so???
Is this the the stream your looking for?
http://streaming.radionomy.com/J-PopProjectRadio?.mp3
Thanks! I will give it a try when I get home! It would be nice to play this again directly from my Essence!
Many many thanks! Tunein does not have very many J-Pop stations, and it hit me hard when Radionomy pulled J-Pop Project Radio and its sister station J-Idols Project Radio from Tunein. These were my two favourties to use with the Essence. They recommended the app which works fine from the iPad, but now I have them back with the Essence remote. The Essence became much more valuable to me again now that Tunein has my stations!
Mark-N: Many many thanks! Tunein does not have very many J-Pop stations, and it hit me hard when Radionomy pulled J-Pop Project Radio and its sister station J-Idols Project Radio from Tunein. These were my two favourties to use with the Essence. They recommended the app which works fine from the iPad, but now I have them back with the Essence remote. The Essence became much more valuable to me again now that Tunein has my stations!
Glad to be of help. TuneIn removed a lot of radio stations because of the lawsuit between Radionomy and Sony Music.
I noticed that in the mean time TuneIn updated also the streams for the Superfly FM radiostation from Austria.
A while ago TuneIn removed also all streams from Jazzradio.com. I have a subscription on Jazzradio.com, so the only way to listen to the stations again on my Moment was to add them as a custom URL, or use the Jazzradio.com app and listen with a Chromecast Audio.
I added them with a custom URL to my Moment and it works fine, only missing the logo's on my Jukebox screen but I have the music again...
I noticed that TuneIn is really caring for its listeners, and if their is a radiostation changing its stream, submitting the form on their website with the new stream address you have is enough to have it back in no time.
