I just got a Beo One Remote that works perfectly with my Beovision 11 but if I try to use my Beo5 or even the Beo4, the navigation buttons have no effect on the Beovision? Surely it must be the same code? Also it seems the Beo One has no effect on my Beosystem 3500 which is in another room?
BenSA:I just got a Beo One Remote that works perfectly with my Beovision 11 but if I try to use my Beo5 or even the Beo4, the navigation buttons have no effect on the Beovision? Surely it must be the same code? Also it seems the Beo One has no effect on my Beosystem 3500 which is in another room?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: BenSA: I just got a Beo One Remote that works perfectly with my Beovision 11 but if I try to use my Beo5 or even the Beo4, the navigation buttons have no effect on the Beovision? Surely it must be the same code? Also it seems the Beo One has no effect on my Beosystem 3500 which is in another room? You must change settings in the Bv11 to let it know you use e.g a Beo4. Also for using the Remoteone on old B&O you must set the remote in Beo4 mood.
Thank you as usual Hiort. One more question, if you don't mind, if I use the Beo5 must I then change the Beovision back to use the Beo One?
Note: there are two user guides for the BV11 - one for with the BeoRemote One and one for with the Beo4.
It might be helpfull to know.
Dear,this week-end I bought a BeoRemote One BT. It works fine with my V1, but I have trouble with my BeoVision 6. I want to change the settings of the BV6, but this doesn't work. More specifically, I can access the configuration screen with the Menu button. From there, I can navigate up and down in the screen with the P+ and P- buttons. However, I cannot select an item to go to the underlying level of configuration settings. IWhat should I do to be able to change the settings of the BV6 using the BeoRemote One? (as I don't have any other remote anymore). For completeness, I have configured the BeoRemote One to work with the BV6 as a BEO4 Video product. Any help is much appreciated.
jans:I cannot select an item to go to the underlying level of configuration settings. I
number + Play
@jans
You'll have to be less cautious - just push the buttons ;-))
