Beo One Remote different to Beo 4/5??
This post has 8 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Sat, Nov 21 2015 4:13 PM
I just got a Beo One Remote that works perfectly with my Beovision 11 but if I try to use my Beo5 or even the Beo4, the navigation buttons have no effect on the Beovision? Surely it must be the same code? Also it seems the Beo One has no effect on my Beosystem 3500 which is in another room?
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Nov 21 2015 4:44 PM
BenSA:
You must change settings in the Bv11 to let it know you use e.g a Beo4.
Also for using the Remoteone on old B&O you must set the remote in Beo4 mood.
BenSA
Posts 1,404
BenSA replied on Sat, Nov 21 2015 4:46 PM
Hiort:
BenSA:
Thank you as usual Hiort. One more question, if you don't mind, if I use the Beo5 must I then change the Beovision back to use the Beo One?
Millemissen
Flensborg, Denmark
Posts 14,680
Note: there are two user guides for the BV11 - one for with the BeoRemote One and one for with the Beo4.
It might be helpfull to know.
jans
Belgium
Posts 394
jans replied on Sun, Sep 25 2016 4:57 PM
Dear,
this week-end I bought a BeoRemote One BT. It works fine with my V1, but I have trouble with my BeoVision 6. I want to change the settings of the BV6, but this doesn't work. More specifically, I can access the configuration screen with the Menu button. From there, I can navigate up and down in the screen with the P+ and P- buttons. However, I cannot select an item to go to the underlying level of configuration settings. I
What should I do to be able to change the settings of the BV6 using the BeoRemote One? (as I don't have any other remote anymore).
For completeness, I have configured the BeoRemote One to work with the BV6 as a BEO4 Video product.
Any help is much appreciated.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Sep 25 2016 5:38 PM
jans:
You have to press the play button instead of the OK button. With the Pause/Stop you navigate back. The Back button won't do the job
jans
Belgium
Posts 394
jans replied on Sun, Sep 25 2016 6:11 PM
Great! That works! Fantastic!
Now I run into the next hurdle! Switching channels on my TELENET STB.
On Beo4 it was something like "channel number" + GO. I can't figure out how to do this with the Beo One.
Any suggestions?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Sep 27 2016 11:35 AM
number + Play
Millemissen
Flensborg, Denmark
Posts 14,680
@jans
You'll have to be less cautious - just push the buttons ;-))
Page 1 of 1 (9 items) | RSS
