Beogram TX2 Turntable Problem
indyaudio
Posts 44
indyaudio Posted: Tue, Jul 24 2012 2:08 AM
Hello all,
I just joined Beoworld. I have a great set of B&O speakers and just picked up a Beogram TX2 turntable with the MMC4 cartridge from the original owner.
I have a problem and need your expert assistance.  There is a little flexible wire/thread that has a loop on the end of it, like a little noose. It is disconnected and I believe it should be attached to the tonearm assembly as it won't move back and forth. When I turn it on, the platter will spin, the lights will come on, will indicate 33 or 45 rpm, but that's it, no tonearm action.
I have dowloaded the service manual and can't quite figure out the routing for this little cable.  I unscrewed the 2 screws and have flipped up the base to expose the guts. Having trouble posting a photo right now....
I did some searching and could not locate an answer. In advance, thanks for the assistance here!
indyaudio
Posts 44
indyaudio replied on Tue, Jul 24 2012 2:23 AM
Managed to post the picture of the TX2 as my avatar, too big to post to the thread, thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 24 2012 6:17 AM
Welcome to Beoworld !
The wire goes to a tiny hook on the foot of the tonearm carriage. This little hook breaks off for
no apparent reason and you will have to make something up to replace it.
I like to fit a 3mm screw through the hole from below, fit a small washer and a nut on top and then fit
the wire to the exposed threading and add a drop of glue to make it stay there.
We've had several threads about this and also some photos.
Do a search in the archived Beogram section.
indyaudio
Posts 44
indyaudio replied on Tue, Jul 24 2012 1:28 PM
Thanks  Martin, very much. I just did a search and came up empty handed.  There was a thread or two about rethreading the cable, but no photos or details. Comment about it being in the service manual available for download.  I don't think I can access it as a newbie.
Any additional help you can offer would be greatly appreciated!
indyaudio
Posts 44
indyaudio replied on Tue, Jul 24 2012 1:34 PM
Found it and downloaded from the Vinyl Engine! I'll see if I can figure it out this evening, thanks again.
Page 1 of 1 (5 items) | RSS
