Moment AUX input delay ?
This post has 7 Replies | 3 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Wed, Oct 19 2016 6:55 PM
Hi..
Has anyone tried to connect a non-B&O tv to the AUX input on the Moment..
The thing that is holding me back is the ability to connect my Samsung TV to the Moment.. How big of a delay on the AUX are we talking about here ? 0,5 second, 3 seconds ?
Anyone ?
/weebyx
ssbrig
Posts 37
ssbrig replied on Wed, Oct 19 2016 10:09 PM
I connected a Pioneer Elite plasma to the Moment and out to a pair of 17's.  The sound delay was terrible, probably about 3-5 seconds - it was not feasible to use the Moment in this fashion for me.
hostler
Posts 49
hostler replied on Wed, Oct 19 2016 10:24 PM
Not quite the same use case, but I run a pre-amplified Phono source into my Moment and experience maybe 1 sec of lag. Now with no picture to align to, it's not an issue for me, but would for a TV source.
Lag is a constant, never seems to change, and not as long as the other response here, of 4-5 secs
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Oct 19 2016 10:49 PM
Too much delay.
New version of the Moment software may introduce a zero delay for the line in port (from what I have been told and similar to what we can find on the A6) but if you have wireless speakers then not sure you can live with the remaining delay.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Weebyx,
You just need to set the "Network Delay" value to zero (or to its lowest value) in the BeoSetup app to remove the audio delay within the Moment (this delay is added to synchronise multiple speakers when playing via multi room).
B&O suggest a small delay of 50-60mS can give some measure of synchronisation if you have B&O products in several rooms linked, without introducing a noticeable lag when connecting a TV.
The factory default setting is 1000mS (1 second) if I recall correctly.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Oct 20 2016 10:15 AM
Steve at Sounds Heavenly:
Hi Weebyx,
Hi Steve
Is this a new setting ? When I asked B&O earlier this year, they said that only BS35 and A6 could have delay set to 0, not the Moment for now ?
Maybe I should borrow one from my dealer and see if it works :)
/Weebyx
Norwin
Frankfurt
Posts 57
Norwin replied on Thu, Oct 20 2016 11:17 AM
Setting was there when I bought it in August. You find it in Beolink section, Sound Synchronization Delays. I have set Network delay, WIFI from 1000ms to 100ms and it works fine with my Samsung TV.
Regards,
Norwin
Beosound Halo, Beosound Core 2x, Beosound 1, Beosound M3 3x, Beolab 18, 19, 12-1, 4000, Beoplay H7, A1, Almando Multiplay Surround Switch
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Oct 20 2016 2:44 PM
Norwin van Mourik:
Wow... that is great news... do you have multiroom, and does that work with the 100ms setting ?
/Weebyx
Page 1 of 1 (8 items) | RSS
