help finding a post (DLNA/tagging/cover/Moment)
This post has 13 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Tue, Feb 28 2017 11:28 AM
Hi all
There was a thread regarding the Moment and DLNA, where a post was made that contained experience and links to tools, regarding id3 tagging and covers and so on.
I simply cannot find it, it was very specific in which tool was used to update tags and covers.
Can someone remember in which thread this was ?
Thanks.
/Weebyx
Barry Santini
New York
Posts 543
Weebyx:
Hi all
Thanks.
/Weebyx
Check out bliss music tagger.
B
Millemissen
Flensborg, Denmark
Posts 14,680
Was it this thread:
http://archivedforum2.beoworld.org/forums/p/20094/165678.aspx#165678
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Feb 28 2017 12:10 PM
Millemissen:
Unfortunately no, it was a post with I think 3 utilities with link to each, where it was mentioned how to add covers to all files, and tag them correct.
but I will take a look at bliss :)
I tried this morning to rip one cd in iTunes, and the install Twonky 8.4 and point my Moment to Twonky, it stood and "harvested" for 1 hour and the one single album was not here yet.
So I am thinking that tags or so a wrong, OR that the Moment does not work with Twonky 8.4 ? Twonky 7.2 did not wotk on my MacBook with Sierra
/Weebyx
Millemissen
Flensborg, Denmark
Posts 14,680
For Win/PC users the most prominent software for tagging is MP3Tag:
http://www.mp3tag.de/en/
Since your location is Denmark (and you are the one who asked), I can point you to another solution (Yate) posted on the forum:
http://archivedforum2.beoworld.org/forums/p/23395/195152.aspx#195152
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Feb 28 2017 12:57 PM
Millemissen:
Thanks, I will try it :)
/Jacob
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Feb 28 2017 1:13 PM
May be worth mentioning that Moment is harvesting the Artist art from Gracenote, based on the artist name provided in the music file metadata. If Gracenote cannot find any image, the tile will be empty. Hopefully there will be a way to manually add artist art.
I have further learned that the data Moment is using for Mood Wheel is based on the artist and song titel, and harvested from Gracenote.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Feb 28 2017 1:28 PM
Hiort:
Ok, I will see if I can get my Album found via DLNA and iTunes later today, I don't think it should take more than 1 hour pr album ? There must be something wrong with my Twonky/Mac/iTunes setup ?
/Weebyx
Chris
Ostend-BE
Posts 1,170
Hiort:
I wonder if it would be useful to fill also mood sphere in tagging your music tracks metadata, whether the Moment this would take into account or only Gracenote's moods list.
Here's an example of Gracenote moods:
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Tue, Feb 28 2017 9:50 PM
Weebyx - Do you see your album in the Twonky user interface? If yes does it have the correct cover ?
Artist image comes from Gracenote harvesting by the Moment. Images are not always found, even for well known artists.
Album cover comes from the DLNA server assuming the tag is readable by Twonky which is not always the case when cover is added via iTunes.
I use Metadatics on the Mac for that
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Mar 1 2017 5:50 AM
mbolo01:
I Figured out that the "Get Album Artwork" in iTunes, does not work with Twonkey, Itunes will show the album, but Twonky will not, however, if you manually select Artwork in iTunes, it updates the tags correct with the image, and all is good in Twonky :) Now to wait to see if the Moment also is happy :)
/Jacob
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Mar 1 2017 7:01 AM
Weebyx:
That is correct. iTunes just put the album art in a separate folder when you do "get album artwork".
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Mar 1 2017 7:10 PM
Weebyx:
If Twonky is happy, the Moment is usually happy too! Reminder: this will solve your album cover image, not the artist image for wich the end user has no control
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Mar 1 2017 7:53 PM
mbolo01:
Reminder: this will solve your album cover image, not the artist image for wich the end user has no control.
Know that it will probably be functionality added so that user can have control of artist images.
Page 1 of 1 (14 items) | RSS
