Hello.
I wonder if I can use playmaker in the new beolink multiroom environment? I would like to connect Beolab 4000 to the playmaker and get them recognised by the BeoMusic application. Would it work? Also, I do not really understand the difference between the playmaker and the B&O Receiver 1? Would both be compatible with the beolink multiform? Lot of questions...
Thanks in advance!
Emmanuel
Hi Emmanuel,
Playmaker is device to which you can Airplay music from e.g a mobile phone. You can then connect your Beolab speakers directly to the Playmaker.
The Beomusic app only work with the newer products with the netlink concept.
Beoreceiver 1 and Beotransmitter 1 are devices you can use when you want a cordless connection between e.g Playmaker and Beolab speakers.
Playmaker is not part of any multiroom solution.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
