Playmaker & Beolink Multiroom?
This post has 1 Reply | 0 Followers
bonbazar
Posts 9
bonbazar Posted: Mon, Nov 21 2016 1:16 PM
Hello.
I wonder if I can use playmaker in the new beolink multiroom environment?  I would like to connect Beolab 4000 to the playmaker and get them recognised by the BeoMusic application.  Would it work?  Also, I do not really understand the difference between the playmaker and the B&O Receiver 1?  Would both be compatible with the beolink multiform?  Lot of questions...
Thanks in advance!
Emmanuel
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Nov 21 2016 9:14 PM
Hi Emmanuel,
Playmaker is  device to which you can Airplay music from e.g a mobile phone. You can then connect your Beolab speakers directly to the Playmaker.
The Beomusic app only work with the newer products with the netlink concept.
Beoreceiver 1 and Beotransmitter 1 are devices you can use when you want a cordless connection between e.g Playmaker and Beolab speakers.
Playmaker is not part of any multiroom solution.
Page 1 of 1 (2 items) | RSS
