Avant Stand Failing?
This post has 6 Replies | 0 Followers
CJM1
Posts 91
CJM1 Posted: Sat, Apr 28 2012 6:44 PM
i received a beovision avant recently from friends. When i used it at there house when it was turned on. it was set to turn towards the desk that was in the room. the next time i went round the stand didn't turn towards the desk when it was switched on. but the stand would move with the remote but it stops at certain points. And now it is in my bedroom, the stand still turns with the remote but stops at certain points and it still doesn't turn when it is switched on and off.
What does this mean?
clarke
david266
Netherlands
Posts 61
david266 replied on Wed, Jul 11 2012 6:46 PM
Hello look at the bottom back side of the avant, there will be an iron thing with two screws, or without this iron plate, there will be only a two screws connection, this side normally is in cross lined with the avant in standby, called 0 in setup stand menu, maybe the settings are changed and therefore the tv wont turn the way you like, settings are found in menu setup stand, stand 0 means standbyposition, 1 the position it goes to when turned on, and a 2 for other but the 0 and 1 are important to set up right way
Good luck
david266
Netherlands
Posts 61
david266 replied on Wed, Jul 11 2012 6:47 PM
Cable connection of the stand motor maybee?
CJM1
Posts 91
CJM1 replied on Thu, Jul 26 2012 10:15 PM
Might be! but the stand moves with the remote control but the 0,1,2 options don't do anything!
kai
Posts 362
kai replied on Thu, Jul 26 2012 10:54 PM
When you are in the menu for stand go to position 0 move the stand via the remote to the position you want then hit go repeat this for position 1 and 2, hopefully that should do the trick
CJM1
Posts 91
CJM1 replied on Fri, Jul 27 2012 2:52 PM
Its not working. i have tried the on screen menu stand presets. I have no clue what is up with it
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Jul 31 2012 12:53 PM
Do you have many cables attached?, what should happen is that there is enough slack in the cable for the stand to move freely  and without obstruction, if the cables are too tight then this could be causing it to stop.
The only other thing I can think is a failing motor
To set it properly call up Menu, Stand and then for 0 use the left and right buttons to turn the stand to where you want it in standby. then press go
Repeat but change to Poisition 1 for the on position, press go when finnished.
Now call up stand on the Beo 4 and press 0 - TV should go back to standby position, then try 1
If this doesn't work then there must be something wrong with the motor or something.
Page 1 of 1 (7 items) | RSS
