i received a beovision avant recently from friends. When i used it at there house when it was turned on. it was set to turn towards the desk that was in the room. the next time i went round the stand didn't turn towards the desk when it was switched on. but the stand would move with the remote but it stops at certain points. And now it is in my bedroom, the stand still turns with the remote but stops at certain points and it still doesn't turn when it is switched on and off.
What does this mean?
clarke
Might be! but the stand moves with the remote control but the 0,1,2 options don't do anything!
Its not working. i have tried the on screen menu stand presets. I have no clue what is up with it
Do you have many cables attached?, what should happen is that there is enough slack in the cable for the stand to move freely and without obstruction, if the cables are too tight then this could be causing it to stop.
The only other thing I can think is a failing motor
To set it properly call up Menu, Stand and then for 0 use the left and right buttons to turn the stand to where you want it in standby. then press go
Repeat but change to Poisition 1 for the on position, press go when finnished.
Now call up stand on the Beo 4 and press 0 - TV should go back to standby position, then try 1
If this doesn't work then there must be something wrong with the motor or something.
