new two way info remote, the BeoRemote ONE BT Bluetooth
This post has 4 Replies | 2 Followers
Robert
Holland
Posts 204
Robert Posted: Thu, Sep 1 2016 11:03 AM
Very nice to see that two way is BACK on the Bang & Olufsen remote. Regards, Robert
Info from whe web:
BeoRemote ONE BT
The days of point and shoot remote controls are over. Operating BeoVision Horizon is based entirely on Bluetooth® technology, which means that you no longer have to point your remote at a certain mark on your screen. Once you press the button the command is carried out. Easy.
One-touch access
Four programmable MyButtons allows you to revisit your favourite TV channels, or custom setups like sound modes and image settings with a single touch.
Two-way convenience
BeoRemote One Bluetooth works with both Bluetooth and IR commands, and because it is a two-way remote control it provides automatic synchronisation between your BeoVision Horizon and your remote. Iconic feel
Robert
Holland
Posts 204
Impression:
Robert
Holland
Posts 204
New BeoRemote One Bluetooth impression, from the web PDF
kuyttendaele
Posts 707
It's been delivered with every BeoVision 14.. so it's been around some time.
Have been using it since a week now.
The BT is 2-way
IR is still one-way.
TWG
Posts 1,672
TWG replied on Sat, Dec 3 2016 9:23 AM
Does the Beoremote One Bluetooth still have the "light" function or is it gone? Can I put "light" onto one of the favorite butons?
Page 1 of 1 (5 items) | RSS
