Very nice to see that two way is BACK on the Bang & Olufsen remote. Regards, Robert
Info from whe web:
BeoRemote ONE BTThe days of point and shoot remote controls are over. Operating BeoVision Horizon is based entirely on Bluetooth® technology, which means that you no longer have to point your remote at a certain mark on your screen. Once you press the button the command is carried out. Easy.
One-touch accessFour programmable MyButtons allows you to revisit your favourite TV channels, or custom setups like sound modes and image settings with a single touch.
Two-way convenienceBeoRemote One Bluetooth works with both Bluetooth and IR commands, and because it is a two-way remote control it provides automatic synchronisation between your BeoVision Horizon and your remote. Iconic feel
Impression:
New BeoRemote One Bluetooth impression, from the web PDF
It's been delivered with every BeoVision 14.. so it's been around some time.
Have been using it since a week now. The BT is 2-way
IR is still one-way.
Does the Beoremote One Bluetooth still have the "light" function or is it gone? Can I put "light" onto one of the favorite butons?
