Avant 4K Help
Solidsnake
Posts 143
Solidsnake Posted: Thu, Dec 8 2016 11:17 PM
I just got a PS4 Pro. I have some games set up to output in 4K but is there anyway to check that the signal being displayed is actually 4K?  The PlayStation settings says it is outputting in 4K.
To check I went into the service menu on the avant / signal information and the Input Resolution says 3840x2160p BUT the Output Disp Res says 1920x1080p
Is there anything I'm supposed to do to enable 4K on the Avant?  I'm using HDMI 1.
Sneak
Posts 8
Sneak replied on Fri, Dec 9 2016 6:45 AM
It's a bug in Avant caused by bypassing "normal" video processing done for FHD and lower.
It's actually outputting UHD, but "signal information" does not pick it up.
Just verifify closly if the OSD menu is bit blurrier than on usual FHD source - if it is - it's on UHD.
Solidsnake
Posts 143
Sneak:
Thanks Sneak.  I wonder if it is the same on the newer BV 14 and Horizon or have they patched the problem?
Sneak
Posts 8
Sneak replied on Fri, Dec 9 2016 2:04 PM
BV14 and Horizon are totally new platform and from the beginning native to UHD - so I assume this problem does not exist there.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Dec 9 2016 5:26 PM
Sneak:
It's a bug in Avant caused by bypassing "normal" video processing done for FHD and lower. It's actually outputting UHD, but "signal information" does not pick it up.
I believe you are correct but I would say it's funny you say it's blurrier in UHD. My impression is rather that it is blurry in FHD since it is upscale to the 4K panel then and not native 4K. AND when playing 4K they show the pixels natively but with a software render at FHD causing it to look pixelated. It's quite fun how they manage to make it so wrong.
Gennaro
Bronx, NY
Posts 78
Gennaro replied on Sat, Dec 10 2016 6:58 AM
I'm assuming u have it in game mode, what kind of input lag are u getting?
I bet the 4K games look amazing
Beovision 11-55, BeoPlay V1 40, Beosound 9000, Beolab 8000's and 3 Beocom 5's... Smile
Sneak
Posts 8
Sneak replied on Mon, Dec 12 2016 6:47 AM
The OSD is 1920x1080, it's "manually" (that's why it was missing in the first release) added to UHD content and streched to cover the whole screen.
Page 1 of 1 (7 items) | RSS
