MX4000 help
timson72
Posts 2
timson72 Posted: Wed, Dec 14 2016 6:06 PM
Hi,recently got MX4000 to do some retro gaming,TV didn't have a remote,got an aftermarket replacement,all works OK but I can't switch to AV1 or 2 ,am I missing something or is it a TV fault?
Peter
Earsdon
Posts 11,991
You need to program the MX sockets - have you got the manual? You go to the menu and you can then set the connections - usually AV1 is V.Tape, AV2 can be CDV and you can also allocate the S-VHS socket to another source. It is all easier with a Beolink 1000! I attach the relevant page!
Peter
timson72
Posts 2
timson72 replied on Thu, Dec 15 2016 8:31 AM
Thanks for reply mate,managed to figure it from some trial and error and googling
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
