Beolab 6000 speakers link to Beomaster 3500 tuner amp
This post has 6 Replies | 2 Followers
Johnm2161
Posts 4
Johnm2161 Posted: Wed, Dec 21 2016 10:15 PM
Is it possible to link a set of Beolab 6000 speakers to a Beomaster 3500 tuner amp?
Thanks JohnM
Johnm2161
Posts 4
Johnm2161 replied on Thu, Dec 22 2016 8:43 AM
Sorry meant to say Beosound 6000 speakers!!
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi JohnM,
No problem!  You just need a Powerlink cable to connect each speaker as the Beomaster 3500 has Powerlink sockets fitted:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Duels
England
Posts 2,553
Duels replied on Thu, Dec 22 2016 8:55 PM
Johnm2161:
I think you were right first timeSmile
Johnm2161
Posts 4
Johnm2161 replied on Fri, Dec 23 2016 1:45 PM
Hi Steve, thanks for your he feedback. I've actually got some of those cables but the Input sockets on the 3500 are a different fitting, the old 2 pin type - 1 round pin and one flat pin.
Do you supply a connector/adaptor?
Thanks JohnM
Posts 2,165
Hi JohnM,
Your Beomaster 3500 should also have 2 x 8 pin Powerlink sockets fitted (assuming that you have the version of Beomaster 3500 shown in the link below):-
https://www.beoworld.org/prod_details.asp?pid=345
For this Beomaster 3500, no adapters are needed, just the Powerlink cables.
Steve.
Johnm2161
Posts 4
Johnm2161 replied on Sat, Dec 24 2016 12:04 PM
Thanks Steve and yes it is that version, much appreciated. I've got your weblink in favs now for future purchases.
best wishes JohnM
Page 1 of 1 (7 items) | RSS
