Is it possible to link a set of Beolab 6000 speakers to a Beomaster 3500 tuner amp?
Thanks JohnM
Sorry meant to say Beosound 6000 speakers!!
Hi JohnM,
No problem! You just need a Powerlink cable to connect each speaker as the Beomaster 3500 has Powerlink sockets fitted:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Johnm2161:Sorry meant to say Beosound 6000 speakers!!
Your Beomaster 3500 should also have 2 x 8 pin Powerlink sockets fitted (assuming that you have the version of Beomaster 3500 shown in the link below):-
https://www.beoworld.org/prod_details.asp?pid=345
For this Beomaster 3500, no adapters are needed, just the Powerlink cables.
Thanks Steve and yes it is that version, much appreciated. I've got your weblink in favs now for future purchases.
best wishes JohnM
