Connecting a Beosound9000 to a Beolink Passive amp ?
This post has 28 Replies | 1 Follower
beofan
Posts 9
beofan Posted: Thu, Jan 22 2015 11:48 AM
Hello, I'm hoping that someone will be able to help me with this as I'm stumped. I have a Beosound 9000 connected to a Beolink Passive amp by both a Masterlink cable and a Powerlink mk2 cable. There is a B & O IR Eye plugged into the Beolink passive amp and a pair of non-B & O speakers attached. The problem is that I cannot get the Beolink passive amp to switch on, or alter the volume using my Beo4 remote control - the Beosound will switch on, the volume goes up and down etc. but no sound because the amp does not switch on -  to operate the amp I have to press the "play" button on the IR Eye, and the same to change the volume, using the up/down buttons. Also, when everything is operating I can only switch it off using the the "play" button on the IR Eye again - the Beo4 remote will not turn it off. Is there a setting that I have missed - or could the IR Eye be faulty (I have only recently bought it) ? Thank you in anticipation.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Jan 22 2015 7:11 PM
Hello beofan,
first of all: You don't need the powerlink connection, only masterlink.
Did you set the correct options?
BS 9000: A.OPT = 0
BL Passive: L.OPT = 6
Regards
Räuber
BeoMegaMan
Posts 601
Depends on how you have it connected. Are you trying to use the passive speakers as the main speakers for the BS9000 or as an additional zone? If it is to be connected to the BS9000 pull the ML and IR connection and ensure you have the thick fully mounted Powerlink connected to the powerlink socket. Then the passive will act as the amp for the BS9000. If it is to be to another zone, connect only the ML and IR and option program correctly.
Ah, you know... A little B&O here, a little there
beofan
Posts 9
beofan replied on Thu, Jan 22 2015 8:32 PM
Hi there, thanks for your reply, yes, the passive speakers are the main speakers for the BS9000, all operating in the same room as one unit. The Powerlink cable is the mk2 (thick) type, I only added it because I couldn't get the system to work with the Masterlink cable, so thought they must operate differently ? I have actually got it to work now, with some additional reading and "trial & error". I added "Link" to the menu on the Beo4 remote, and if I select "Link" first, then press "CD" or "Radio" it nows works as I expected - but I don't know if this is the correct way to do it ?
beofan
Posts 9
beofan replied on Thu, Jan 22 2015 8:51 PM
Raeuber:
Hello beofan,
BS 9000: A.OPT = 0
Regards
Räuber
Hello Rauber, thank you for your reply, that is very informative, I did not realise that it was possible to set different options for both the BS9000 and the Beolink passive amp - the reason I added the Powerlink cable was because I could not get the amp to respond with the Masterlink connection, and thought the two cables must operate in different ways. I have actually got the amp to work with the BS9000 now, by adding "Link" to the Beo4 remote menu, and selecting "Link" then CD or Radio - I can now work the volume, change functions, and switch it off using the remote. As to the option set - I think it is A.Opt 4, but I set that by pointing the remote at the IR Eye (with the BS9000 shielded in a cupboard), so don't know whether to try changing anything - or just leave it as it is, since it seems to be working ?
BeoMegaMan
Posts 601
If the amp is connected to the 9000 as the main speakers you do not need to ML to it or have the IR. The amp connected with only powerlink and no IR will turn on and off with the 9000 and act as if the 9000 is one unit. The 9000 would also take all the commands without link needed. As you have it now it is acting as if the amp is another zone/room, hence the reason you need to hit link etc. Your setup can act as one piece if you link without an IR.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Jan 22 2015 9:38 PM
As BeoMegaMan already wrote, the Beolink Passive should function as an amplifier without the ML and ir. Only the powerlinkcable should be fine.
BS9000 in option 1.
Make sure that with (un)plugging, you take the power from the 9000. It detects when powering on if the powerlink is used.
beofan
Posts 9
beofan replied on Fri, Jan 23 2015 4:12 PM
Thank you for all the replies, I think I understand more about connection methods now than I did yesterday. The IR Eye I will keep connected , as the BS9000 is in a cabinet with a drop front (so it can be out of sight), the Eye means I can still operate it when the cabinet is closed. I'll leave the extra cable (Masterlink) connected, simply because the routing means it's a struggle to remove again - but at least I'm clearer on the option settings now. Hopefully this thread may help anyone else who is stuck too .
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jan 23 2015 4:29 PM
Hi beofan,
please keep us informed whether your system will work with Masterlink cable and the IR eye.
But don't forget to set the correct options: BS9000 = A.OPT=0 (so no reaction on Beo4 commands) and BL Passive = L.OPT=6 (not A.OPT!), so no more LINK command is needed!
Regards
Räuber
Amazone
Netherlands
Posts 187
Amazone replied on Fri, Jan 23 2015 8:06 PM
When you have only speakers connected to the passive, you should only connect the thick powerlink cable. You do not have to use any link commands and the passive will work a being part of the 9000. You don't need to operate it and It will switch on and off fully automatically.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Beobuddy
Posts 3,972
Beobuddy replied on Fri, Jan 23 2015 8:36 PM
Just tested this.
Only a passive with fully powerlink without ML or ir. It works great.
As I already mentioned. Power up the BS9000 when cables are connected.
Millemissen
Flensborg, Denmark
Posts 14,680
Has worked a thousand times before - so why shouldn't it in this case?
The BL Passive (as an amp) is one of the oldest and most reliable pieces of B&O hardware, that we have!
I have used several in different setups for years without any trouble.
If used this way, it is just an amp that triggers on the right PL cable - nothing special there.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jan 23 2015 9:33 PM
But beofan wants to hide BS 9000 in a cabinet and therefore he wants to use the IR eye. So he can use a masterlink instead of a powerlink cable. This will also work fine, why he shouldn't do it this way?
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Of course he can!!!
But why should you hide a BS9000?
Never heard of that before Confused
N.B. I did write 'The BL Passive (as an amp).......'
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Jan 23 2015 10:18 PM
I didn't ever hear of somebody who hides a Beosound 9000, only an Essence, Playmaker or Moment...
Millemissen
Flensborg, Denmark
Posts 14,680
Raeuber:
Aha!
And how (and why) would you hide a BS Moment?
Just don't say, because it looks like it does Crying
You would not be able to use it then - you probably would not buy it either.
beofan
Posts 9
beofan replied on Tue, Jan 27 2015 11:22 AM
Since a couple of people have queried why I have the BS9000 in a cabinet that can hide it, two reasons - first it keeps it from getting covered in dust (it's not the easiest thing to clean thoroughly and carefully), and secondly, for security reasons (when I don't want such an expensive item visible all the time). I should add that generally the cabinet door is open so I can enjoy the "show" when CD is on random Big Smile I'd post a picture (which would make all clear), but I don't know how to do it on here.
beofan
Posts 9
beofan replied on Tue, Jan 27 2015 11:28 AM
A quick update, as I have now had time (work permitting) to properly act on the useful advice that people have been kind enough to give. Masterlink has been disconnected (so only Powerlink2 connection now), IR also removed, and BS9000 set to A.Opt 1 - now it works just as I wanted, so thanks to all for their help. Smile
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Jan 27 2015 11:50 AM
Great news and thanks for the update.  Not everyone is so considerate to show the resolution to their problems.
Dave.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi beofan and thanks for getting back on the subject.
You can post pictures from a browser on PC/Mac - not on an iDevice.
Use the 'Reply' button, and you will se some options for adding photos etc..
It should be possible to add pictures using the Beoworld app too - but I have no experience how to, since I only use the standard browser version of the Beoworld site.
beofan
Posts 9
Thanks MM, this is the setup for the BS9000, I quite like the look of it in this cabinet, the backlights are a recent addition Smile
Abeng
Philippines
Posts 3
Abeng replied on Mon, Feb 29 2016 8:33 AM
How about my source is beo essence to a beolink passive to drive beovox 2.2 ? it auto on when recieved a signal but i cannot turn the volume up or down. but i can power it off only .  please advice ... thanks
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Abeng,
are you sure, that you use the right (fully monted RJ45 to Din) PL cable from the Essence to the Passive amp?
alex_112
Posts 38
alex_112 replied on Tue, Jan 10 2017 8:49 PM
Millemissen:
Hi Abeng,
Would you be able to change the volume on the passive with powerlink2 connected or do you change on the connected device?
BR
  //Alex
BV14, BV10, BeoGram 3000, 4500, BS 9000, Moment, Core, Ouverture, Essence, Beo6, BROneBT, BeoTime, ML/NL, BLGW, BeoLab 2, 11, 18, CX100, BeoPlay A6, M3, E8/H3/H8
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Jan 10 2017 9:42 PM
I have my Essence driving a Beolink Passive which drives some outdoor speakers. The first cable my dealer sold me did not work, even though their documentation said it would. It only works with one type of cable - the powerlink mk2.
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Jan 10 2017 9:43 PM
alex_112:
BR
  //Alex
You change the volume on the device driving the Passive.  The Passive itself has no volume control.
Millemissen
Flensborg, Denmark
Posts 14,680
Usually when we talk about the BeoLink Passive, we mean the box (connected to ML) and the connected ir-eye for local control.
However when the box is used just for amplfication, there is no ir-eue connected. Only the (right) PL cable and the (passive) speakers cables (and the power cable).
Since it merely is an amp, all controls are done in the main system (as Stan wrote).
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, Jan 11 2017 2:44 PM
Good point MM.  Thanks for clarifying.
Stan
alex_112
Posts 38
alex_112 replied on Sun, Jan 15 2017 8:57 AM
Great, thanks!
Page 1 of 1 (29 items) | RSS
