Beogram 1200 5 pin din plug
Vantard
Posts 3
Vantard Posted: Thu, Jan 19 2017 10:41 AM
Hi I recently have acquired a 1200 turntable, unfortunately the din plug has been cut.
I have exposed all the wires, but  I would love to have the correct wiring details for the pin.
Can anyone help.....
Pictures to follow
Vantard
Posts 3
Vantard replied on Thu, Jan 19 2017 11:02 AM
beo3000
Posts 109
beo3000 replied on Fri, Jan 20 2017 10:23 AM
Red is right black is left, you have 2 grounds, that should be kept separate the furthest out braid gets soldered onto the casing of the din plug, the other ground the 2 braid's against the red and black wire get twisted together and put on to the center pin of the 5 pin din the right and left are on one side pins 3 and 5, look at phono stereo that is what you want to do just has the extra earth I mentioned before and the the blue wire in the diagram is black in your case Image result for 5 pin din wiring diagram
beo3000
Posts 109
beo3000 replied on Fri, Jan 20 2017 10:27 AM
use the rean gold plugs not those cheap ones they are much better
Vantard
Posts 3
Vantard replied on Fri, Jan 20 2017 10:35 AM
Many thanks for the detailed reply. I will also take your advice on the Rean din plug.
Page 1 of 1 (5 items) | RSS
