Hi I recently have acquired a 1200 turntable, unfortunately the din plug has been cut.
I have exposed all the wires, but I would love to have the correct wiring details for the pin.
Can anyone help.....
Pictures to follow
Red is right black is left, you have 2 grounds, that should be kept separate the furthest out braid gets soldered onto the casing of the din plug, the other ground the 2 braid's against the red and black wire get twisted together and put on to the center pin of the 5 pin din the right and left are on one side pins 3 and 5, look at phono stereo that is what you want to do just has the extra earth I mentioned before and the the blue wire in the diagram is black in your case
use the rean gold plugs not those cheap ones they are much better
Many thanks for the detailed reply. I will also take your advice on the Rean din plug.
