Mein Bang&Olufsen:
BeoVision 7-55 MK2 BluRay 3-D , BeoLab 7-4 (center) BeoLab 5 (front) , BeoLab 3 (rear) , BeoSound 9000 , Remote ONE , MLGW , BeoSound Core , BeoLink NL/ML Converter
BeoVision 7-40 MK6 BluRay 3-D , BeoLab 7-2 (center) BeoLab 3 (front) BeoLab 2 (sub) BeoRemote One
BeoVision 6-26 MK 4 , BeoRemote 4
BeoLab 2000 , BeoCom 5 , BeoCom 2 , BeoPlay A2 , BeoPlay P2 , BeoTime , BeoPlay H9i Rimowa , Beoplay E8 2.0
Hi Spotti,
die BS5 gibt dir das, was es finden kann - manchmal miserabel, ja!
Die einzige Möglichkeit - die Cover ersetzen (manuell so zu sagen) durch bessere.
test
http://archivedforum2.beoworld.org/forums/p/21821/189369.aspx#189369
