Build quality Horizon - Is this normal?
boh48
Posts 1
boh48 Posted: Sun, Feb 5 2017 12:54 PM
Just bought a Horizon TV, the speaker grill is not 100% same color, is this normal? And 1 of the corners of the aluminum frame, is not perfect assembled, it has a small gap in the back ... is this the way these TV are?
leosgonewild
Helsinki, Finland
Posts 2,373
You pay for design. Take it back.
Michael
Sweden
Posts 2,578
Michael replied on Sun, Feb 5 2017 2:12 PM
I would return it instantly.
Millemissen
Flensborg, Denmark
Posts 14,680
Did you confront your dealer with this?
Simonbeo
Posts 1,451
Michael:
or paint the wall black.
Seriously, the execution of the frame should appear perfect or at least be designed to be of repeatable good perceived quality.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
StKong
Copenhagen
Posts 320
StKong replied on Mon, Feb 6 2017 12:12 AM
boh48:
Just bought a Horizon TV, the speaker grill is not 100% same color, is this normal? And 1 of the corners of the aluminum frame, is not perfect assembled, it has a small gap in the back ... is this the way these TV are? Do I have to high expectations of build quality?
Bad quality control. Looks like it's been on the floor.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Mon, Feb 20 2017 7:00 PM
My Horizon does not have those problems, this is not acceptable and I would advice you to return your TV and let it be fixed under warranty.
Page 1 of 1 (7 items) | RSS
