Just bought a Horizon TV, the speaker grill is not 100% same color, is this normal? And 1 of the corners of the aluminum frame, is not perfect assembled, it has a small gap in the back ... is this the way these TV are?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Did you confront your dealer with this?
Michael:I would return it instantly.
or paint the wall black.
Seriously, the execution of the frame should appear perfect or at least be designed to be of repeatable good perceived quality.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
boh48:Just bought a Horizon TV, the speaker grill is not 100% same color, is this normal? And 1 of the corners of the aluminum frame, is not perfect assembled, it has a small gap in the back ... is this the way these TV are? Do I have to high expectations of build quality?
