Beosound Essence Remote control: Manufacturer? Update? Fix?
TWG
Posts 1,672
TWG Posted: Wed, Feb 22 2017 12:46 PM
the Beosound Essence remote controls are simply beautiful and a pleasure to use - but there's a major(!) design flaw while using infrared mode: The steps send by the volume wheel are way to big!
I know immediately when my wife uses the remote e.g. in the living room as the volume jumps up very high if you turn the wheel like you would with a conventional volume wheel on any other amplifier.
You have to use the volume wheel like a surgeon in infrared mode and that is not very comfortable. A volume control is something you shouldn't need to think about and I'm not planning to place a warning sign next to the remote on the wall ;-)
So: Is there a way to fix this? Can B&O update the remotes or does anybody know the original manufacturer of the remotes?
Maybe we could make a little petition for example to ask B&O to fix this to make the remote a pleasure to use in infrared mode, too!
Too many people outside this forum don't seem to know - as always - that that nice little remote thing is of so much use.
egges
germoney
Posts 303
sorry TWG,
i can´t confirm your issue. Both , the wheelie and the IR-eye itself, control the volume as smooth as expected with my Essence MkII, no matter which source is playing. i´m in mode 1
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
CB
> You are Here <
Posts 1,762
CB replied on Wed, Feb 22 2017 4:54 PM
I have the same issue with my wheely controlling my BL5s. Large steps and moreover, long offset at first use after a period of inactivity.
If it's OK with an Essence box ## in IR ##, then it's probably because the wheely is (only) made for the Essence box, not everything else Sad
Page 1 of 1 (3 items) | RSS
