Beogram 8000/5613 to Beomaster 3000/2933 connectivity
cyberg
Posts 2
cyberg Posted: Fri, Feb 24 2017 6:14 PM
I am looking for a din/din cable that will connect this turntable to this tuner/amp. All I can find are cables which connect the turntable to non-B&O amps (din to RCA). Is the din/din cable readily available?
Thanks.
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Feb 24 2017 8:18 PM
I am sure Steve would make you one - you do need the specific cable as it is shielded and the casings are connected. Otherwise you run the risk of hum.
Peter
cyberg
Posts 2
cyberg replied on Fri, Feb 24 2017 11:09 PM
Thanks Peter. Steve also contacted me in regards to the cable I need.
Page 1 of 1 (3 items) | RSS
