I am looking for a din/din cable that will connect this turntable to this tuner/amp. All I can find are cables which connect the turntable to non-B&O amps (din to RCA). Is the din/din cable readily available?
Thanks.
I am sure Steve would make you one - you do need the specific cable as it is shielded and the casings are connected. Otherwise you run the risk of hum.
Peter
Thanks Peter. Steve also contacted me in regards to the cable I need.
