Beolab 8000 / beolab 2 problem.
This post has 11 Replies | 2 Followers
andrew
Sussex UK
Posts 47
andrew Posted: Mon, Apr 10 2017 8:03 AM
Hi. Yesterday I finally got my beolab 2 installed with my beolab 8000s. I was delighted with the sound - really amazed. Played a few CD's - then went to play another and nothing. Red lights on all 3 speakers. Nothing working - I have just tried them again this morning and again - nothing.
Any advice on what I can do, what might have happened, would be very much appreciated. I'd bought the Beolab 2 from eBay and found it didn't work so had it repaired - new driver. Costly! And having JUST got it all up and running, needless to say, I feel gutted.
Andrew
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Andrew,
If all three speakers are showing red lights, why not unplug the Beolab 2 and plug one of the 8000s into that cable?  If this works then you are likely to have a faulty sub.  If this doesn't work then it may well be a cable issue.
I'm happy to send out new cables on a 60 day trial period for you to check the speaker if you wish?  You can see the cables for your speakers here:-
http://soundsheavenly.com/powerlink-8-pin-din-connection/20-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html
Please let us know how you get on!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
andrew
Sussex UK
Posts 47
andrew replied on Mon, Apr 10 2017 9:27 AM
I have checked this morning, by unplugging the beolab 2 and connecting the 8000s directly to the beomaster 7000 that the system itself is working fine. Then I reconnected everything including  the beolab2 again - and this time, the beolab 2 didn't light up green OR red. No light in fact. Perplexed - I am back to having the beolab 8000s alone for the moment ...
Posts 2,165
Thanks Andrew,
This sounds like a faulty subwoofer - if there is no light, the subwoofer may not be getting mains power, are you sure the power outlet/cable/fuse are all OK please?
Steve.
andrew
Sussex UK
Posts 47
andrew replied on Mon, Apr 10 2017 9:29 AM
Thanks Steve. I shall almost certainly be buying some cables from you for this system anyway - the ones that came with the speakers are FAR too long for my needs ...
Posts 2,165
Thanks Andrew Smile
Hope you manage to get the Beolab 2 sorted.
Steve.
andrew
Sussex UK
Posts 47
andrew replied on Mon, Apr 10 2017 10:18 AM
Steve - following your suggestion I prefaced the fuse in the subwoofer plug - and all is fine now. I do feel silly! Any way - thanks. It was a 3 amp fuse so I replaced with the same - hope that is correct.
I shall measure the flexes and order some suitable shorter.
Andrew
andrew
Sussex UK
Posts 47
Andrew
andrew
Sussex UK
Posts 47
andrew replied on Mon, Apr 10 2017 10:20 AM
Replaced the fuse, not prefaced ....
andrew
Sussex UK
Posts 47
Posts 2,165
Hi Andrew,
That is good news!  Yes, a 3 Amp fuse is correct for Beolab 2.  You may find that the sub occasionally blows this fuse in normal usage, but I would still recommend using a 3 Amp fuse instead of 5 Amp, for better protection.
Steve.
andrew
Sussex UK
Posts 47
andrew replied on Mon, Apr 10 2017 10:31 AM
Thanks Steve. Solved! Will be in touch soon re leads ...
Page 1 of 1 (12 items) | RSS
