I had the issue when ripping cd's in iTunes, but that was because of the ID3 tags not being correct. I just changed them in iTunes, and reset the local cache on the Moment, and then all was fine again :)
/Jacob
Justin:Thanks Jacob. I indeed changed tags afterwards and cleaned the cache of the moment as well as Twonky but no help. Perhaps I should try to remove the files completely, delete cache and add them with again... Thanks
If the ID3 tags are the same on the "various" albums, as the ones that are working, then there must be some "cache" that is not cleared on the Moment.
Is the albums correct in the Twonky interface ?
Justin:a fair amount of albums are being placed under the 'Various Artist' tile.
mbolo01:Aren't these albums set as Compilations ? If they are they will appear in VA on the Moment an in Various in Twonky BS Moment, BL 18, BL 19, A6, M5, A1, H5
Justin: All tags are just fine.
Justin - Ca you confirm if these albums have or not the "Part of Compilation" tag set? If it is the case they will appear under various in Twonky and under Various Artists in the Moment.
This type of thing seems to be the bane of streaming music collection software, I know with iTunes I've had to go in over and over to try and clear out metadata issues that keep songs splayed out over multiple "albums" of the same title instead of all together. Sometimes no matter what I do to make the metadata correct it still won't arrange things properly. I think a lot of the problem, at least for iTunes, is a problem with iTunes, but even more a problem with Gracenotes, which iTunes gets the metadata from when you import an album, I have to think Gracenotes is fubar'd a lot.
Every time I think I finally have all my iTunes stuff sorted out I'll find another album or three that are messed up while browsing through my library. Frustrating.
Jeff
mbolo01:Justin - Ca you confirm if these albums have or not the "Part of Compilation" tag set? If it is the case they will appear under various in Twonky and under Various Artists in the Moment. BS Moment, BL 18, BL 19, A6, M5, A1, H5
