BeoSound Moment --> WebInterface?
This post has 8 Replies | 2 Followers
DocLeisure
Posts 101
DocLeisure Posted: Wed, Apr 26 2017 3:29 PM
Hallo,
kann man die BeoSound Moment vom Rechner aus bedienen, bzw. Einstellungen ändern? Wenn ja, wie?
Danke für eine kurze Antwort.
Gruß
Doc Leisure
Aussie Michael
Melbourne, AU
Posts 3,730
All the other devices that are NL have a web interface like the BS1, A6, A9 (not the Avant)
How i found is that i logged in to my router (Netgear Genie) and that shows you what devices you have connected.
When you log in to the web interface its the same as the "Beo Setup" app
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Apr 27 2017 5:25 AM
Aussie Michael:
correct for NL devices - but not the Moment
Aussie Michael
Melbourne, AU
Posts 3,730
Isn't the moment an NL device?
It shows up in the BeoApp though?
Maybe its like the Avant then - hidden.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Apr 27 2017 7:45 AM
type the IP address of the moment in your browser and see for yourself
and yes the moment is a NL device
DocLeisure
Posts 101
that was the first thing I tried -> typing in the IP address of the BeoSound Moment.
The result: "No such file" (--> the browser is pointing to the "index.fcgi")
So there seem to be no easy way to access web front end - but maybe a hidden one? Is there a specific port address? Or any other way to get in?
Best regards
Doc Leisure
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Apr 27 2017 9:24 AM
DocLeisure:
Best regards
Doc Leisure
If there is, for sure B&o hasn't communicate it.
No such link in BeoSetup app, no such link in BeoMusic app, no such link in BeoTool app!
Matthaeus123
Posts 162
Es gibt eine Möglichkeit, jedoch ist diese extrem umständlich und nutzt quasi nichts.
Die Moment läuft unter einer Android System.
Dieses kann durch eine komplizierte Tastenfolge auch gestartet werden. Und ist dann auch vom Computer aus bedienbar.
Erleichtert aber keines Wegs die Bedienung oder ähnliches!
DocLeisure
Posts 101
Moin,
rein aus Neugierde, wie ist die "komplizierte Tastenfolge".
Ausprobieren würde ich es gerne mal ;-)
Gruß
Doc Leisure
Page 1 of 1 (9 items) | RSS
