Hallo,
kann man die BeoSound Moment vom Rechner aus bedienen, bzw. Einstellungen ändern? Wenn ja, wie?
Danke für eine kurze Antwort.
Gruß
Doc Leisure
All the other devices that are NL have a web interface like the BS1, A6, A9 (not the Avant)
How i found is that i logged in to my router (Netgear Genie) and that shows you what devices you have connected.
When you log in to the web interface its the same as the "Beo Setup" app
Aussie Michael:All the other devices that are NL have a web interface like the BS1, A6, A9 (not the Avant) How i found is that i logged in to my router (Netgear Genie) and that shows you what devices you have connected. When you log in to the web interface its the same as the "Beo Setup" app
correct for NL devices - but not the Moment
Isn't the moment an NL device?
It shows up in the BeoApp though?
Maybe its like the Avant then - hidden.
type the IP address of the moment in your browser and see for yourself
and yes the moment is a NL device
that was the first thing I tried -> typing in the IP address of the BeoSound Moment.
The result: "No such file" (--> the browser is pointing to the "index.fcgi")
So there seem to be no easy way to access web front end - but maybe a hidden one? Is there a specific port address? Or any other way to get in?
Best regards
DocLeisure:Hi, that was the first thing I tried -> typing in the IP address of the BeoSound Moment. The result: "No such file" (--> the browser is pointing to the "index.fcgi") So there seem to be no easy way to access web front end - but maybe a hidden one? Is there a specific port address? Or any other way to get in? Best regards Doc Leisure
No such link in BeoSetup app, no such link in BeoMusic app, no such link in BeoTool app!
Moin,
rein aus Neugierde, wie ist die "komplizierte Tastenfolge".
Ausprobieren würde ich es gerne mal ;-)
